Question about Pentax Optio S5z Digital Camera
My Pentax Optio s5Z is stuck on one mode
My Pentax Optio s5Z wont take pictures. When you turn it on, the screen shows whatever you're pointing the camera at, just like you were recording a video or something, but it's completely unresponsive when you push ANY buttons. Anyone have any answers?
  • Anonymous Jan 24, 2008
    I have had the same problem the whole time Ive owned it..If I had it on video camera setting and turned it off it would do it, I had to turn it off, put in the memory card it came with and then turn it on, move it out of video camera, turn off and then put the bigger memory card in and then I was ok.. But now that my girlfriend lost the original memory card Im pretty stuffed..Any other Ideas any one?
  • Anonymous Mar 16, 2014
    the camera refuses to start when it is switched on
I also had this problem. I think it is caused when the camera is turned off while in the viewing part of the camera. That is, I had gone to look at the video that I had just taken, but didn't and then turned the camera off. The camera is then as you have described it.
The only way I could get it back to normal is to connect the camera to the computer, using the cable, and download the photos and videos. When the download is complete, disconnect the camera and it should be OK.
Good luck, cheers. Phil
Posted on Oct 30, 2007
SOURCE:
I was given a Pentax Optio s5z the camera does take pictures - however it does not take them or put them on the picture card - only on the camera which only holds about 5 pictures - once I put in the...
What type and size memory card are you trying to use? The S5z works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Oct 01, 2013 | Pentax Optio S5z Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
My Pentax Optio S5z locks itself somehow. Before it usually unlocked on it's own also. Now it is stuck on LOCK and I am not able to delete pictures, or use the MENU or MODE buttons. I am able to take...
Is the slide switch on the side of the card in the unlocked position? If so, try this...remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 28, 2009 | Pentax Optio S5z Digital Camera
Lens on Optio S5z will not retract. When turned
Please view my FixYa tip on this subject for a complete walkthrough of the potential causes and solutions.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Many thanks for using FixYa.
Dec 18, 2009 | Pentax Optio S5z Digital Camera
Instruction manual for pentax optio s5z
I could send you a copy of the manual on CD.
Where do you live?
May 10, 2009 | Pentax Optio S5z Digital Camera
Memory card size
The S5z is limited to SD cards, 2GB and smaller. The speed doesn't matter, but larger cards will not work in this camera.
Aug 26, 2008 | Pentax Optio S5z Digital Camera
Unlock Pentax Optio S5z
I had the same problem with the exact same camera (Pentax Optio S5Z) that happened the same way. I searched everywhere on the web and finally found this post that didn't have a solid solution. So I started experimenting with different button combinations and finally figured it out.
Hold the OK button while turning on the camera. The screen should indicate that it is in audio record mode. Now press the Menu button and use the navigation keys to find and execute the system reset option.
After turning it off and back on it should function normally.
Mar 16, 2008 | Pentax Optio S5z Digital Camera
Pentax s5z doesn't take any more pictures
Here's another method to fix this problem.
Push the ON Button for some while and you will go to MEMO recording screen, in this mode the MENU button works and you can RESET the camera.
Cheers Phil
Aug 29, 2007 | Pentax Optio S5z Digital Camera
Pentax Optio S5z Digital Camera Logo
121 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
