Question about Hoover F5906-900 Upright Steam Vacuum
Hoover Upright Steam vac
My steam stopped sucking up the water. I am inthe middle of cleaning...What is wrong with it. I have had no problems in the past. Help, Cypress
  • 625 Answers
Re: Hoover Upright Steam vac
Is there a float switch in the tank? Could be when the float rose up to a level it got stuck, stopping your machine.
Posted on Sep 10, 2007
0 characters
3 Points
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My hoover spin scrub steam vac stopped sucking up water
Only 2 possible probelms.
The vacuum adapter in missing from the dirty water tank.... OR the intake part of the machine is clogged and must be cleared of hair and dirt (with the supplied plastic wand)
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction in new Hoover Steam Vacs hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
There is no steam on my hoover steam vac
They do not really "steam." They use hot water to clean your carpets with a mix of cleaner as well. You will not see your unit actually steam.
Dec 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5906-900 Upright Steam Vacuum Logo
262 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
