Question about Hoover HF7 160E Front Load Washer
Hoover washing machine HF7160E
Fills with water then dont do anything when on spin emptysmakes a noise like it should be doing something but nothing happening i checked belt its ok well until my husband took it off and cant get it back on so i need to two things a idea whats wrong with it and also how do ya get belt on as we cant
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Posted on Sep 09, 2007
SOURCE:
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Started a load of laundry water filled fine started washing and agitating and then heard a weird noise like something got stuck and went and it sounds like motor is running but will not agitate or spin and...
Please give a make and model of washing machine. I suspect that something has stripped out between the motor and the transmission, which is the noise you heard.
Jan 24, 2009 | Washing Machines
HNF7167 Hoover Washing machine no spinning
how do i put the belt on my washing machine
Dec 07, 2008 | Hoover AAA160 Front Load Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Hoover HF7 160E Front Load Washer Logo
202 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
