Question about Akai LCT3201AD 32 in. LCD Television
Won't turn on now
14 month old Akai LCT3201AD wouldn't turn off with remote yesterday until I got with in a few feet of sensor. Changed batteries now the TV won't turn on. Push power on set or remote, green light comes on for a few seconds then switches back to red. Tried unplugging the power over night. Same response as last night, then wouldn't turn green at all. Unplugged it again for 30 minutes, back to green light coming on for a few seconds then back to red. Help, were do I take it? can it be fixed? Live in rural northern Minnesota.
  • 4 more comments
  • Moonchild628 Dec 23, 2007
    We are having the same problem! TV won't turn back on... was working fine yesterday. Now, as the previous poster said, the light turns green for a few seconds, like it's going to turn on, then goes off. Same results with remote or using TV controls. TV is about 1 year old..
  • sgroom26 Jan 10, 2008
    We too have this problem. The television was working just fine then suddenly one day it just stopped turning on. Nothing unusual happened prior to this problem, eg no sudden power surge, the set wasn't dropped etc. Now the light comes on for a few seconds, then turns red and there is no picture. The television is only about a year old. I can't find any help thru customer service.
  • Anonymous Jan 26, 2008
    We had the same problem with the remote I bought two universal remotes and they won't work with it either.
  • Anonymous Feb 01, 2008
    won,t turn on
  • fbords Feb 26, 2008
    I too have this issue on occasion. Unplugging it for a few minutes allows me to turn it back on. Sometimes, it will stop responding to my commands either by remote or the side buttons. This has only happened a few times. Also, when turning it on, I have to wait about 30 seconds after the AKAI splash screen before I can change sources or do anything. Any ideas? Mine's an LCT2721AD.
  • Anonymous Mar 13, 2014
    I have tried the remote, the power button on the tv and unplugging it. None of these work. The red light stays on and it should be green if powered on.
Ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Posted on Jan 21, 2008
Is vga connection being used? if so try unplugging vga dont know why but it helped me.
Posted on Feb 26, 2008
Thanks Fred31; I did that and it worked for a while...we were afraid to shut it off, so we just left on for a couple of weeks! Hubby was vacumming and unplugged in accidentally...we have been unable to turn on ever since. Gave up and bought a new tv. Thanks for trying!
SOURCE:
I need the remote control for LCT3201AD
To check if your remote is working,put in fresh batteries and using your camera fone or a normal fone press on the remote and see if you can see a light emmiting from the front end of the remote to your camera. if you see a light than your remote is fine but if you dont than your remote is faulty and needs to be serviced or replcaed.
Good luck.
G..
Nov 08, 2011 | Akai LCT3201AD 32 in. LCD Television
Remote control stopped working. Changed batteries and still no luck. Any suggestions?
good way of testing remote is point it at camera on phone( turn on camera first) and look for flashing light when pressing buttons if no light then remote faulty if it flashes then fault might be with re-server in tv
Oct 22, 2009 | Akai LCT3201AD 32 in. LCD Television
My remote broke and I can't find a replacement that will work.
I crushed my AKAI remote a week after I got it and I purchased a Logitech Harmony remote. It's kind of expensive (100.00) but you install the software in your computer and connect the remote to your computer. A screen comes up and you can type in an unlimited number of devices. All you do is put in the brand and model number and the computer will program the remote for that device. I have at least 10 different devices programmed into mine and works perfectly. Actually the price isn't bad because they wanted 85.00 to replace the remote just for the TV.
Jul 12, 2009 | Akai LCT3201AD 32 in. LCD Television
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Jan 10, 2009 | Akai LCT3201AD 32 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Need a stand and remote control for Akai LCT3201AD
Please check this Weblink as they might help you to provide desired parts for you Akai LCD TV.
Jul 27, 2008 | Akai LCT3201AD 32 in. LCD Television
Panel buttons and remote controls are both erratic
Problem seems in panel board having bad switches. You probably need to replace the (control) panle board. Check out this Weblink having info for Akai TV parts.
Jul 21, 2008 | Akai LCT3201AD 32 in. LCD Television
Power supply
Hi, this was for the TV model LCT3201AD. My TV was about a tear old when the TV went out. It may be that the power supply is out. TIto
Jul 06, 2008 | Akai LCT3201AD 32 in. LCD Television
See my other support issue regarding a simillar problem: http://www.fixya.com/support/t155367-red_line Since this is a row of dead pixels and the TV is under warranty, you need to either contact the manufacturer or even exchange it at the retailer you purchased it from.
Jun 22, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
2,330 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
