Question about Canon Rebel XT / EOS 350D Digital Camera
LCD Display When taking a picture I am not seeing any display in the LCD.
  • 1 more comment
  • nick1234 Nov 06, 2007
    When taking a picture I am not seeing any display in the LCD camera is a vivitar
  • JasonFlash Dec 04, 2007
    Hi, I have the same problem with my Rebel shooting with or with out CF nor with the lens attached. Pls let me know a.s.a.p
  • Lindow Dec 19, 2007
    My canon rebel digital XT used to display image on LCD monitor BEFORE I took the picture but does not now. It does display images taken.
I used to see the screen before taking a photo as well. Now it doesn't show anything. Whether this is 'normal' or not, I want to be able to see the screen again. This is a very expensive camera and I want to be able to have the functions I had when I first bought it, just a few months ago! I can still look at the photos after taking the picture but the screen is not working before. In the book, it shows the screen working before.
Posted on Dec 20, 2007
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
If you mean you see no picture on the lcd monitor before you take the picture and see it only after you have taken it than this is normal with digital SLRs. But if you mean you see nothing on the lcd monitor after you have taken a picture ( no playback ) then either the shutter is not working , or the CMOS sensor is not working or the camera is not communicating with CF card.
Posted on Sep 16, 2007
How can I get the LCD to turn on?
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
Jul 20, 2014 | Canon Cameras
LCD Screen
Your camera is working exactly as SLRs have worked for the first half-century since their invention. You frame the picture through the viewfinder then take the shot. The display is for menu settings and reviewing pictures after they've been taken. Newer DSLRs will let you use the display for picture-taking (and take videos) but the A200 belongs to the previous generation.
Mar 26, 2014 | Sony Alpha DSLR-A300 Digital Camera
No lcd display and no pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 27, 2009 | Canon PowerShot G5 Digital Camera
I dropped my sony alph 100 digital camera and display wont work
Do you see Menu items or Menu Display in LCD?
If yes then LCD connector might be displaced and requires re-installation and if no, then LCD seems broken.
May 31, 2009 | Kodak EasyShare One Digital Camera
Canon sd900 will only take pictures that don't require a flash
Press the "DISP" button. Button on the top right of the bigger circle control button.
You can turn off the display if you want to conserve battery and use the viewfinder. So you probably accidentally turned it off. You can use that button to turn on/off the LCD display or change between two brightness settings on the LCD.
Hope that fixes your problem.
Apr 19, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
LCD Problem
I have seen backlight problems on the external LCD display. Take a flashlight and shine it on the external display to see if you have a picture. If you can see a faint picture, most likely either the backlight or backlight inverter has failed. Those LCD modules can be tricky to service because of the size. I would recommend a qualified tech for the job
Oct 18, 2008 | Sony Handycam DCR-TRV720 Digital Camcorder
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
Sep 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
243 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
