Question about Toshiba 57H81 57" Rear Projection Television
Pip board bad
My Toshiba when you first turn it on the picture is all mixed up, you can not see anything way out of focus, after its on for about 3 to 5 min it becomes clear. A local tv repair man told me he has fixed the problem on others, he said it was the pip board, does that make sense? and if so can i buy on and install myself?
    Champion:
  • 317 Answers
The scan converter/hyper needs a rebuild it needs to be done by the experienced..john
Posted on Sep 12, 2007
My picture in picture isn't working?
Most of these sets have two tuners--one for main and one for PIP.
If main picture works fine but PIP is bad or Green? either the PIP tuner or the PIP board is bad---these were known to have the PIP have problems but it was more rare than their sets made before it.
SD TECH
Apr 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Out of focus tv picture
if you have already adjusted the focus pot on the line o/p transformer (a small transformer with a lead that has a plastic cap attached , and is typically clamped onto the top of the crt/tube BE CAREFUL DONT TOUCH CAP WHEN TV ON VERY HIGH VOLTAGES)
also could be your crt/tube is bad if so then scrap/recycle
cheers
Jun 16, 2008 | Toshiba Televison & Video
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Apr 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Coaxel and composite jacks produce scrambled picture, componite ok.
Bad hyper board = repair by qualified tech, PCB not available...
Feb 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
