Question about Samsung SyncMaster 204t 20.1" Flat Panel LCD Monitor
Blank Screen The screen was fading when i returned from vacation. I restarted and it came back black. I can still access the desktop via Go To my pc like the screen is on but when in front of the computer its still black.
  • dee sandif Feb 02, 2009
    I have double the trouble,
    I just had two Samsung syncmaster 204T LCD 19' inch displays go bad on me.....at the same time!!!
    They are both blank, no images whatsoever, not even on the on board monitor configuration application will come up when I push the source or menu buttons. There is a green light on the power button, but that's it, not a dam thing else. I swear, this is starting to seem like a corporate conspiracy to me....
    They are both blank, no images whatsoever, not even on the on boardmonitor configuration application will come up when I push the sourceor menu buttons. There is a green light on the power button, but that'sit, not a dam thing else. I swear, this is starting to seem like acorporate conspiracy to me....
It's very likely that the LCd "inverter" is bad. This is a module that provides the high voltages needed to light the 4 cold-cathode lamps that provide the white backlight. Search for other samsung problems with inverter and you should find several. The one I saw was for 17" LCDs and the 204T is probably using a different module. Should be able to find replacement online, but be prepared to take the monitor back cover off, with tiny screws and connectors.
Posted on Sep 25, 2007
SOURCE:
Blank Computer Screen
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including Black screen
After that restart your computer in safe mode by press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode
Inn safe mode Update your graphic drivers from your system manufacturer site
If this is helpless then simply get Reginout that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors.
Hopefully it will help you
Jun 24, 2013 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Ml-780 screen
Common fault. LCD fails. Very expensive. Usually comes on then fades to black or has stripes down half of display. Try a half clear first. If that doesn't solve it, almost certainly LCD panel failure.----------------------------------------If anyone needs more information, the Towa/ Geller ML-780 manuals are here:http://the-checkout-tech.com/manuals/cashregisters/towa1.php
Jan 13, 2012 | Casio Parts Cash Register PC Desktop
My screen is blank when I turn the computer on?
If you have recently connected a second monitor, and have since disconnected the second screen, the primary screen will be completely black. Restart your computer and this should fix it. If it continues, your screen may have over-heated, in which case it needs complete replacement, or it may need to cool down.
If you have an LCD screen, check the power cable connections on the back of your sceen making sure they are connecting properly. If all is connected and you have tried to restart - your screen will need to be replaced.
Nov 15, 2010 | HEWLETT-PACKARD Hewlett Packard Compaq...
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Video driver disabled. restarted. no beep and black monitor
  1. Turn on the PC
  2. As it is booting, keep tapping the F8 key until options appear on a black screen (you should see these)
  3. Choose VGA Mode option (or similar)
  4. Then enable your driver again or reinstall it
nLinked
Computer Support Services
Jun 07, 2009 | E-Machines eMachines Desktop PC
Blank screen Compaq Presario 1200 notebook
you have changed the settings
do you see screen of bios?
if yes then u will have to run the machine in safe mode and change the resolution
Nov 07, 2008 | Compaq Presario 1200 Notebook
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Blank screen
restart pc.....and tap F8 the second the PC starts boot till screen asks you to choose "Safe Mode" in save mode right click the desktop and set the properties back to what it was b4.
Let me know if your successful.
Nov 11, 2007 | Sony VAIO PCG-K23 Notebook
Samsung SyncMaster 204t 20.1" Flat Panel LCD Monitor Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
