Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Wiring Hampton Bay Fan
I have two switches on the wall. One was for light and the other fan blade movement. We had a problem and someone installed a new hampton bay fan when buying the house. Now both fan and light work off only one of the two switches. I undid cover for fan and see that i have white, black and red from ceiling. I have black red white bule from fan. How do I get these circuits to work independently as before? green is to ground on fixture. Thank you
  • donald lee Apr 24, 2008
    1 got a hamptonbay 52in the light kit copme with a white little platic with 9 hole is that where the light kit connection
  • 153 Answers
The blue wire is for the light.This should connect to the other switch instead of being combined with the fan switch.
Posted on Sep 09, 2008
2 Suggested Answers
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
Ac5520d Hampton bay ceiling fan only works on one speed
A couple of things, did it just happen or did someone move it to another room. Those fans have switches an or capacitors that change the speed. I don't think the wiring inside failed because that rarely happens. But most likely it's the switch or capacitor failure.
Jul 19, 2017 | Hampton Bay Dryers
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Fan running & stops then goes the opposite direction
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Sep 09, 2017 | Hampton Bay 52 In. 5-Blade Fan, Aged...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
94 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
