Question about Curtis-Mathis CM19011 TV
Tv will not come on....it was on a few minutes ago
Ok I have no clue what my kids did.....but I can not get our tv turned on....they came to me and the tv was on but no sound...tried to turn the volumn up on it but manually and the menu screen was coming on after I hit the volumn buttons on the tv...so i tried the remote and the remote will not access the tv (it's the tv remote that came with it)so i turned the tv off to turn it back on now nothing please help me i have a 4 and a 6 year old...everything is plugged in , i have power and i need help
  • presious21 Sep 10, 2007
    thank you...it was a loose wire.....i also found out that my kids spilled milk on the speaker wire...and pulled it out to dry it off....thank you for the help...it works now
Speaker wires got pulled out from mother board
Posted on Sep 22, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As you say that sound is not ok other thing is normal please check the following 1 speaker and its wire for loose 2 supply to sound section and loose print 3 parts in audio out put section kids can not create any problem from outside. regards
Posted on Sep 10, 2007
SOURCE:
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Beovision 3 (8803) standby ok - no picture - no sound
if you know how to use soldering iron,try to resolder your tv,especially the jungle,regulator and the horizontal section.if not working, check the output transistor a square black plastic w/ 3 legs at the back of the plyback.
Jul 29, 2009 | Televison & Video
Rca model f20352sf
I just read this solution online a few minutes ago, so i don't know how accurate it is, but
someone was having problems viewing DVD. So maybe it will also work for your xbox.
And I quote:
VCR - tune TV to channel 91
DVD - tune TV to channel 92
Someone else posted if these didn't work, try channels 00 or 01.
Hope this helps.
Oct 12, 2008 | RCA F20352SF TV
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Samsung t.v. picture going in and out
it may sound like you have a input or a output problem if you have a video un plug it from the tv. and put your Aral strait to your tv that will tell you if your video is the problem not the tv.
Jan 07, 2008 | Samsung DLP HL-P5663W 56" TV
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Screen is messed up, getting worse
What your describing sounds like two differant problems OR the power supply is causing these two problems .. One would of course be the tuner and the other would be the vertical circuit .. Your going to need to seek out a profesional if you havent a clue about solid state electronicsand A tv is not a place to experiment! Good Luck
Jul 27, 2006 | Panasonic CT-36SX31 36" TV
Curtis-Mathis CM19011 TV Logo
141 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
