Question about Whirlpool Calypso GVW9959K Top Load Washer
LD ERROR CODE
Whether we start a new load or it is in the middle of a load it randomly pops an LD CODE I've read what the code means but I'm not sure which step to take to try to fix it. your help would be much appreciated. Thanks
  • stanyul Aug 19, 2008
    ld error code pops and machine stops spinning in the rinse cycle.
    And a slight oder, like burning.  How do you disconnect the drain hose?
  • 641 Answers
Check that the drain house is clear from kinked or clogged. Let me know if you will need for further assistance. Good luck!
Posted on Sep 09, 2007
Disconnect the drain hose and run water through it. If it does not flow easily then you might have something like change stuck in it. Suffered this problem for 1 year until I read this solution. Technicians had no clue. It is very easy to disconnect...
Posted on Sep 22, 2007
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
I have a a kenmore oasis ld error cod
ld error code is long drain some thimg clogged up pump ,, first check drain hose could be too far down and siphoning,, if not repl/ or cleaned out pump.....
Dec 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite LD Error
LD means long drain. First check to make sure that there is nothing stuck inside your drain hose. The next thing to check is your pump. lean the washer back and locate the pump. Next take it loose and clean out any debrit inside it. That should take care of it. If not check your lid switch.
Nov 17, 2008 | Washing Machines
Ld and ob error codes
hello.........
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
993 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
