Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Trouble only one line vertical
The best and first thing is reduse brightness to avoid crt demage 1 check circuit between horl output to yoke horihontal winding 2 check h yoke connection 3 boost capacitor generally low value &high voltage
Posted on Sep 09, 2007
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Vertical 1 line
Check voltage supply at vertical amp ic ,if present than change vertical amp ic.Some times supply line is dameged by faulty amp ic.therefore you have to rctify supply and replace ic.Check supply line fusible resistors.
gopal
Dec 13, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
