Question about JVC XA-A50CL 128 MB MP3 Player
Won't stay on
AQgian like many others the head phones when you get done dowloading or Sync. The headphones will say on then turn off. MAybe there is someone fronm JVC that accually has instructions on how to use these things.
0 characters
1 Points
Hi when i dowloading the i tunes from the internet my ipod is connected to the laptop and after finshing the download the screen of the i pod doesnot appear when i coneect to the laptop its shows the...
1. If you have enabled AutoSync, everytime the iPod is connected, the iPod will sync all your files. It is not only the songs that are copied. It also copies the videos, photos and contacts too. Maybe it was trying to sync them.
2. Even if it had really done with sync of all songs, video, photos and contacts, it will always show the message "Do not disconnect". What you will have to do is click on the eject button in the iPod icon which appears in iTunes. The iPod will be ejected only when you eject it from the iTunes.
May 04, 2011 | MP3 & Digital Media Players
My apple i pod will not play threw the head set or any other device pluged into it.It only plays on speaker mode.Is there a way to turn speaker off so it plys thre headset again,or is the jack input broken
It should automatically switch to the headset mode when you put headphones into the headset port on the top.
Try other headsets or go into itunes and select to restore your iphone. It will sync everything over again, but might fix a software fault.
If neither of those things help, take it to your local apple store or call them on 1800 My Apple (US phone number).
Hope that helps. If it gave you a little information, please rate accordingly :)
Apr 22, 2011 | MP3 & Digital Media Players
I have a Creative Zen Vision M (30 Gb) and am suddenly having some strange problems with sound. My usual headphones are now producing sound out of only the left channel. When I tried other headphones...
Hi if you are having head phone are giving you different sound from different head phones you have a head phone jack that is not connection properly. Some times the head phone jack can be replaced and that will fix it. other times the whole main board will have to be replaced due to a chip on the main board is whats causing the sound to change like it does. Try moving the jack around by twisting it and moving it from side to side while in the players whole. If the sound seems to change, start working on both side or you get static. as long as the sound you are getting is not staying the same then I would say its the head phone jack itself. It the sound stays the same witch is sounds like ti doesn't from what you have stated then it would be the main board. Either way something needs to be repaired.
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at from my web page at Thanks
Dec 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
Head ear phones works
have you tried other headphones or earphones
some headphones lose connection in the wire  and will cause a short where one side works and the other doesnt
if this is not the problem may have a lose jack on the inside of the player and will probably have to have it serviced
May 01, 2009 | SanDisk Sansa e250 MP3 Player
My headphones wont work everthing else is fine
Hi There,                The input for the head phone is a 32 ohm input. You need to get the proper 32ohm headphone for it. It seems that you tryed others but there are 16 ohms and 32ohms headphones. But if they do not work then it is your input connection or the device if your headphones work on other devices.You should bring the product back as a faulty device to the store and exchange it with your reciept then.  For the headphone that works on one side it can be the headphone jack that does not fit properly into the hole input (female jack).The one side does not touch or connect for it to work. It happens to cheap headphones and some good ones too. The male jacks on the headphones are slightly off it specification size by a small amount that it is not noticed by the naked eye, so it does not get a good connection.Try another head phone if you haven't tryed that
Mar 26, 2009 | MP3 & Digital Media Players
Head phone jack
Any other headphones to try? maybe even a friend's? I suspect it is a problem with the "phones" themselves even if they are new.
Feb 16, 2009 | SanDisk Sansa e260 MP3 Player
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
No head phones work
sounds like the socket for the headphones is kaput..maybe there's something inside of the hole?
Mar 02, 2008 | RCA H100 MP3 Player
Head phone not working
maybe disconnected tha other side of headphone
Sep 27, 2007 | SanDisk Sansa e130 MP3 Player
Head phone of Ipod
maybe the jack of your headphone is broken. Try with other headphones to see if you hear from the two ears.
Jul 14, 2007 | SanDisk Sansa e250 MP3 Player
JVC XA-A50CL 128 MB MP3 Player Logo
Top JVC MP3 & Digital Media Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
sonic boom...
sonic boom...
mac colar
Are you a JVC MP3 and Digital Media Player Expert? Answer questions, earn points and help others
