You need to clean the indoor coils with a coil cleaner. Its probably mold that has been dormant until you turned the unit on and it became wet. Clean the indoor coil real well with an approved cleaner. Some Home Depot's carry a coil cleaner that is in a spray bottle.
Comments:
Apr 11, 2009
- Absolutely! You can also find a coil cleaner there at Home Depot also that is a no rinse cleaner. You just have to put it in a spray bottle and spray it on. The unit needs to be running when you clean it so it will pull the chemical through the coil. It may blow bubbles but don't be alarmed. Just try and get it as clean as possible or you will have to buy another. A dirty unit will burn it up too. Have a great weekend and if you need more help, post a comment and I will get to it as soon as I can. Be positive........you can do it!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire FAC107P1A
Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on...
(More)
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on cord,worked fine last time i used it
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit...
(More)
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit after about 15 minutes started to drain all sorts of water out the back drain and now is making a knocking noise?
we bought ours from lowes and it was the display item it came with no instructions, can you tell us...
(More)
we bought ours from lowes and it was the display item it came with no instructions, can you tell us how to mount the pieces onto the unit (side and top pieces) before we install it in the window......
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I...
(More)
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I think the problem is with the control panel any suggestions?
where does the white and black wire from the power cord hook to under the panel? I know where the...
(More)
where does the white and black wire from the power cord hook to under the panel? I know where the green goes. My cord got pulled out
