Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem in pc
My computer is corrupted with strong virus & i dontknow what is that &how to get rid of it.b'coz of this there is booting problem ,and most of the times i have to install window media again & again .I will be thankfull to u .
    President:
  • 2,961 Answers
If you have an anti virus installed, turn off system restore and then, restart your pc but press F8 while it's booting and get into safe mode, highlight start windows in safe mode, press enter and run the antivirus programme, if you dont have one then download a free one from here http://filehippo.com/download_avg_antivirus/
Posted on Sep 09, 2007
I think u are using so many disks and pen drives from others. So don't bring any file from other's pc. bcoz each time you brings any file or any data from others virus comes with it and to solve it i suggest you to Formate your HARDDISK fully. I think it will solve your problem. If not Please Inform. Thanks
SOURCE:
How do I get rid of a yellow brightness box that has come up in the middle of the desktop and won't move
Step 1: I would suggest you to boot in safe mode with networking and check if you face the same issue. To boot into safe mode refer to the link
provided below: a)Restart the computer. b)Start tapping the F8 key.
c)You will get advanced boot option window. d)Select the option “Safe mode with networking”
Step 2: Put the computer in clean boot and check to see if the issue still persists. Note: After troubleshooting, make sure to put the computer to normal startup. If the issue doesn’t persists when the Computer is in clean boot or while in the Safe Mode with Networking, then the issue is confirmed to be caused by a certain non- Microsoft applications.
Method 2: This issue might be caused due to viruses. I suggest that you scan your computer from Microsoft Safety Scanner, which would help us to get rid of viruses, spyware, and other malicious software.
May 25, 2015 | Compaq Presario 7478 PC Desktop
Free antivirus program
You don't have a question here, but I will comment on AVG. I used to use AVG and have Beta Tested both AVG and AVAST. AVAST I can set up a Boot-Time Scan and with AVG I can not. Importance of a Boot-Time Scan, is getting rid of persistent viruses. There is NO, and I mean NO antivirus program that totally works under Windows. The Boot-Time Scan works under DOS and runs before windows is loaded upon your next restart. It takes longer, but it works very well. Depending on the size of your hard drive and the number of files on it, it can take as long as 2 to 2 1/2 hours. It is automatic, so walk away and when you see windows has loaded, then the Boot-Scan has finished. There is a log file that you can view to see what it found if you want to look. Once AVG let a virus into my computer, I went to AVAST and never went back, mainly because AVAST works and also the Boot Scan feature that AVAST has. Years ago, there was a DOS based virus scan that I had used on a Floppy Disc to rid computers of nasty virus attacks and infested PC's. It was proven to me that only a DOS based program can rid any virus a PC is infected with. With the free version you do not necessarily get all the help you need, but with the paid versions you will get all the Bells and Whistles. While free is alright to try, I recommend you Buy! This keeps software development going in the right direction and improvements flourishing.
Sep 04, 2014 | Internet Avg AVG Security V8.0 WIN - 2...
Rom flash corrupt
When your computer won't boot there are several things that could be wrong. The first that is most common is a virus got on your computer and corrupted the OS. The second is the Hard Drive is failing and the third would be bad drivers or program got installed.
I would first reboot your computer and right before the Windows loading screen comes up, hit F8 every half a second until a menu comes up. The first thing on the menu to try is Boot Windows in the Last Known Good Configuration. If that doesn't work repeat the process and try booting in Safe Mode or Safe Mode with Network Connectivity. If your computer won't boot after trying each one, there is a possibility that there are hardware issues or the OS is to corrupt to start. If this is the case you will need to take it in for an IT Professional to look at. If you can get it to boot, then scan for viruses with a program called ComboFix from bleepingcomputers.com then make sure that you uninstall any recent programs.
Dec 05, 2013 | Compaq Evo D500 PC Desktop
I have a Virus how do I get rid of it
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
hope it helps
Nov 26, 2012 | E-Machines eMachines Desktop PC
Computer very slow ,won't print,forever to load pages, have corrupted files
Several things can slow down the computer: overheating, spyware, not enough RAM etc. If you know for sure you have corrupted files were they corrupted by a virus? You may need to reinstall Vista.
Is it slow when you boot up in safe mode? To boot into safe mode hit (usually) F8 while it is booting up. Let it completely boot into safe mode and then reboot again. Now is if it is behaving better.
To get rid of spyware download the free Spybot Search & Destroy from the net, run the update and then run it to dectect and get rid of the spyware. Spyware tries to send info which can slow down everything.
Overheating - does it feel hot? Is the fan running and pushing air?
If it worked fine before it is unlikely you don't have enough RAM. Windows itself needs at least 256mbs to run well without running other problems.
Again if you know files are corrupted, if they are windows files, you might need to reinstall vista.
Feb 22, 2011 | Microsoft Windows Vista Home Basic Edition
Ii have with virus one more how to set up driver with song ,
Good day!
you can thoroughly scan the entire system using an anti virus software to get rid of the virus:
i can refer you to use a avg anti coz it can do internal and extral scan into your software,including your system file and data link libraries.
if you have deeper question about anti virus and virus, kindly pm me.
follow this link for anti virus official website: http://www.freeavg.com/?lng=ph-en&cmpid=corp
happy scanning....=)
Dec 08, 2010 | Gateway 832GM PC Desktop
An xp pro sp3 computer got infected with XP Security Firewall Alert. Using Malware Bytes, Spybot Search and Destroy and some other products I was able to get rid of the virus but now have an endless boot...
Looks Like the NTDetect.com is corrupted
1. Boot the windows XP in Recovery Console Mode
2. copy ntdetect.com from the i386 folder and paste it from the root directory
3. type exit and restart the computer it should push through
Nov 16, 2010 | Computers & Internet
I think I went to a virus riddled website. My computer shut down. Now when I restart it, it comes on for a few seconds and a blue screen pops up and tells me Windows is shutting down to prevent damage. How...
avg makes a down-loadable boot disk download this and burn to disk select your dvd/cd as your first boot device then and follow on screen prompts. the virus as corrupted the MBR (master boot record ) that may have to be repaired after the virus is removed
Oct 21, 2010 | Computers & Internet
My computer has been infected with the Total Security 2009 virus.Does anyone have any idea how to get rid of it?
Download, install and run full scan with following
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Sep 25, 2009 | Microsoft Windows XP Home Edition
Norton 360 says scann is running when it is not. cann not connect to support. "program not respondig" message
I've this happen to me in the past. In my case, a virus had infected my computer and corrupted Norton to make it appear like it was running when it wasn't. Make sure the problem isn't a virus first, and then try to reinstall Norton if there is no virus. I would try a virus scan at safety.live.com or download AVG free from downloads.com
Jul 14, 2009 | Symantec Norton 360 2.0 for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
