Question about Cell Phones
Installing Language/Font on Samsung Phone
I'm trying to install Russian Language & Cyrillic font on my Samsung SGH S300 mobile phone but I have no idea how to do it. can anyone help?
  • 31 Answers
SOURCE: how to download hindi fonts
You need to go into the Sony Ericsson service point and ask them to replace the firmware with one that supports hindi language, font installation is only possible this way.
Posted on Feb 17, 2009
SOURCE: Increase font size on Nokia E65 Mobile Phone
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Posted on Mar 22, 2009
  • 175 Answers
SOURCE: How to enlarge the font in the text messages in Samsung D-780
hi..while viewing a text message, just hit the volume
on the side of the phone.This will change the font size
larger and smaller accordingly.
check it out..
thank u..
kindly rate my response..
Posted on May 08, 2009
PHoNE LANGUAGE SETTING FOR I900 SAMSUNG MOBILE How do I change the language setting from germang to english for my samsung SGH -i900
Posted on Aug 07, 2010
SOURCE: My SAMSUNG mobile s5233 dont
how to add more fonts in samsung s5233 mobile
Posted on Nov 15, 2010
SOURCE: samsung s5620 msg font size how to small
You have to open a message in your inbox and use the volume key to make it smaller or larger. Hope this helped you.
Posted on Jan 09, 2011
0 characters
1 Points
Does samsung monte s5620 support ebuddy??? i installed couldnt install language...language installation fails..!whats the reson?
Ebuddy works on all Java mobiles.Downloading English is always Recommended.There are lots and lots of Mobileapp sites like, u can get this app!
Jun 11, 2011 | Samsung S5620 Cell Phone
Aug 07, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Mobile internet tricks for samsung sgh e 250
how to change font in mate 3313 go to setting and click display and light there u find 4 font here u change it
Feb 23, 2010 | O2 Samsung SGH-E250 Cellular Phone
How do i make the font bigger on my impression phone?
you have to change to a different font type to change the size
You can use this method to change the Font size; from the standby screen; press menu, settings, display & light, font type, select desired font type, then press save.
Dec 11, 2009 | Samsung SGH-A877 Impression Cell Phone
How to change language to english
Hi friend,
If there is English language in your cellular phone,you just need to set it,you can get more information,you may visit our website:
But if there is not English languge,you can only install the English language,but it will cost much money.
Sep 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
I am also having the same proble moreover same ..
you cant install tamil fonts without modifying your phone...and by modifing you risk the fact that you are going to brick your phone and make it completely useless.
also some one must create the font pack, and i really doubt that they might create it for an indian language where very little people require it
Aug 05, 2009 | Sony Ericsson K750i Cellular Phone
Font size of a text message in a samsung sgh-700
thr is no sch option provided in ur cell to change d font size....u hav to wrk wid d same!!!!!
Jan 01, 2009 | Samsung SGH-L700 Cell Phone
Samsung sgh-e250 text font, sound, and message tone
you go to messages then to create msg then options den scroll down then you will see text size and click then click the left navigator then click apply
Apr 24, 2008 | Samsung SGH-D900 Cellular Phone
Tamil fonts for k 750i
I have installed tamil bible on k750i but it displays just boxes pls help me call om 9972252270 its very important
Mar 06, 2008 | Sony Ericsson K750i Cellular Phone
Cell Phones Logo
575 people viewed this question
Top Cell Phones Experts
Are you a Cell Phone Expert? Answer questions, earn points and help others
