Question about GE JVM2050 Microwave Oven
Microwave won't come on
My daughter ran the microwave (A space maker 2.0) last night without any food in it. (She thought she was setting the timer) Now our rather brand new microwave will not come on. We checked the house circuit breaker for the microwave. We even reset it. Currently I have diconnected power while I am searching for other possibilities. Any assistance will be so much appreciated.
  • 209 Answers
I am a recently retired appliance engineer of 20 years, i am reluctant to help with microwaves because of the dangers, the store electric even when unplugged, but it sound just like an internal fuse, these are special quick blow types, can be bought from most electronic high store shops, and replacements must be exact match, if a replacement blows there is another fault and don't recommend self repair work with safety and remove the plug first etc oh the fuse is just inside following the mains wire in, and normally on a small circuit board if i have helped please rate me
Posted on Sep 09, 2007
I pulled the door off my advantium today to clean it after I cleaned the vent grille. I set the door carefully on it's side so I thought but a small little plastic piece broke off where the door...
Glue won't work, the part must be replaced.
We have the service manual at our site and you can download it free here.
You can order parts from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Advantium 120 Convection/Microwave Oven
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
I THOUGHT I SET THE TIMER-YET I HAD SET THE
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Kenmore microwave wont heat food
I would suspect you have a failed high voltage transformer or maybe magnetron.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find exploded views and part prices by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
May 30, 2008 | Microwave Ovens
GE JVM2050 Microwave Oven Logo
198 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
