Question about Sony Handycam DCR-TRV280 Digital Camcorder
Handy cam hi8 dcr
Started to eat one of my tapes. Wouldn't eject it. Finally did eject it and allow me to get the cassette out but then it wouldn't close. I let it sit open for a month (forgot about it). I always store it plugged into the charger. Battery life shows full. I was able to put the head cleaner tape in today but it just said re-insert cassette and now it won't eject it. It is open, and partially ejected but won't allow me to open it to get the cassette out. Just sticking out of the machine. Can't get cassette out or push it back in. Battery has never been replaced.
    New Friend:
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Posted on Aug 28, 2013
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
Posted on May 28, 2008
aneesh ch
  • 73 Answers
SOURCE: My tape will not eject!!!
u must to open ur camera and eject motor u put 3 dc volt then it eill eject and clean all connect then fixit and try
Posted on Jul 09, 2009
welcomejee
  • 10594 Answers
SOURCE: tape deck won't close after tape inserted sony dcr-trv103 r
Do you see any error code flashing at top right in camcorder LCD?
Let me know that error code please.
Posted on Sep 03, 2009
SOURCE: tape wont eject of dcr trv340 e (sony handy cam) ???
I have a dcr trv340 and the tape keeps coming back out.
Posted on Nov 11, 2009
  • 30 Answers
SOURCE: my trv 238e camcorders heads must be cleaning, but
A much better way to clean cassette heads is to get some cotton buds and a Can of Servisol Video 40. You should be able to get the Servisol from places like Radio Shack or if in the UK somewhere like jessops or Maplin. I have also seen it on Amazon.
Just spray it on the head (only a small amount) then wipe of the dirt with a bud.
Thanks
Posted on Mar 06, 2011
Tape stuck
DIY remove Hi8 tape stuck camcorder Check this link as it might help out to remove the cassette.
Jan 23, 2014 | Sony Handycam DCR-TRV30 Mini DV Digital...
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Tape wont eject of dcr trv340 e (sony handy cam) ???
Feb 18, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
Jul 23, 2006 | Sony Handycam CCD-TRV107E Camcorder
Sony Handycam DCR-TRV280 Digital Camcorder Logo
177 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
