I have a list of dtc's that I pulled from the car with some discriptions that I can give you. I just need a place to start with the problem
The barometric pressure (BARO)
The manifold absolute pressure (MAP)
The intake air temperature (IAT)
The engine RPM
P0121
The predicted air flow and the predicted MAP combined are outside a calibrated range for more than 3 seconds.
Circuit/System Testing
Inspect thoroughly for any type of leak or restriction
Air leaks at throttle body mounting area and intake manifold sealing surfaces
Throttle body for dirt, debris, and coking--Refer to Throttle Body Cleaning.
Increase the engine speed slowly to 3,000 RPM, then back to idle.
Exit from the snapshot and review the data.
Observe the Mass Air Flow (MAF) Sensor parameter frame by frame with a scan tool. The MAF sensor g/s should change smoothly and gradually as the engine speed is increased and is returned to idle.
If the MAF sensor g/s does not change smoothly and gradually as the engine speed is increased and is returned to idle, refer to DTC P0101 or P1101.
Broken throttle shaft
Any throttle body damage
If any of these conditions exist, replace the throttle body assembly.
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
Your vehicle has an electronic throttle body unit so it uses voltage signals to control throttle blade in the throttle body. There are a few different issues that can cause this problem.
First off there is a update for the PCM to address those codes, but you will have to take it to the dealer for that.
Second there is issues with the actuator on the throttle body binding up and causing the codes.
Third there is a yellow wire coming off the throttle body connector that breaks inside internally and cannot be seen to the naked eye. The best way to test that is to grab the wire about 5 inches from the connector and tug if it feels spongy or breaks, that
According to the manual
P0700 = EATX Controller DTC Present
Discription= An automatic transmission input DTC has been set in the transmission controller.
P1733 no listing in manual
P0743 =Torque Converter Clutch Soleniod/Trans Relay Circuits
Discription= An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit (3 speed auto RH trans. only).
hope this helps
