It is a one year old frigidare heat pump unit, got power at plug and reset works but the digital display will not come on, havent used it in about 6 months.
You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on...
(More)
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on cord,worked fine last time i used it
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit...
(More)
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit after about 15 minutes started to drain all sorts of water out the back drain and now is making a knocking noise?
we bought ours from lowes and it was the display item it came with no instructions, can you tell us...
(More)
we bought ours from lowes and it was the display item it came with no instructions, can you tell us how to mount the pieces onto the unit (side and top pieces) before we install it in the window......
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I...
(More)
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I think the problem is with the control panel any suggestions?
where does the white and black wire from the power cord hook to under the panel? I know where the...
(More)
where does the white and black wire from the power cord hook to under the panel? I know where the green goes. My cord got pulled out
