Question about iRiver H320 MP3 Player
IRiver Can't get it to switch on. On the screen it states either charging or connected when its not charging or connected to the pc. Please help me !
  • Anonymous Nov 17, 2007
    i deleted the root folder by mistake ... please tell me how to make a root folder...
You may have tried it already, but there is a tiny hole on the side (under the microphone?) which is a reset switch. Push a pin in there.
Posted on Nov 09, 2007
Problem with above solution is that you need it to turn on to upgrade the firmware!
Posted on Oct 28, 2007
    Problem Solver:
  • 15 Answers
Obviously, if it's still under warranty, you know what to do! I'm not familiar with this particular model but, unless you and I are missing something to do with the controls, then it sounds like a software 'crash'. These players are basically empty chips which need to be filled with a program to make them work - just like a computer. You should have had a Firmware Disc supplied with your player. If you don't, then go onto the manufacturer's website and down-load it from there. Follow the instructions for 'Firmware re-load' carefully. This will wipe the existing (faulty?) program and your music files, and basically reload a fresh copy of the Firmware onto your player to get you back to the position you were in when you first got it! Good luck, and please report back about the result.
Posted on Sep 09, 2007
SOURCE:
IRiver H320 won't boot...
format is exactly what you have to do...but this how you do this...plug iriver
to pc..goto my computer see the iriver...click on and copy all software only (hidden also) from iriver and save to temp folder on pc...now format the iriver.......okay....now copy from that temp folder (the iriver software) back to the iriver.....put you audio/video on its like new again...
Jun 03, 2010 | iRiver H320 MP3 Player
Iriver B30 can't connect to PC
driver is need.search in net
Dec 05, 2009 | Computers & Internet
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
hope this helps.
Here is for the Iriver H10 software:
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
Iriver H320
there is a setting somewhere that stops it charging when you connect it to a usb port on the computer.
May 08, 2008 | iRiver H320 MP3 Player
E10 Problem
You need to upgrade the firmware by using iriver plus 3 in the 'tools' section it should have upgrade firmware.
Nov 13, 2007 | iRiver E10 Digital Media Player
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
Iriver ihp120
Back in the tools disk is an option for infa red input/output connection to your computer. Some how this option was activated, and it is looking for your wifi.
Jun 05, 2007 | iRiver H320 MP3 Player
iRiver H320 MP3 Player Logo
62 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
