1985 Yamaha XJ 700 X Maxim Logo
A
Anonymous Posted on Aug 26, 2013
Socket size need remove spark plug
What size socket is needed to remove spark plugs on a 1985 yamaha maxim xj700
  • Allen Sorrow
    Allen Sorrow Mar 18, 2024
    5/8 of an inch socket is what you need 3/8 drive with a ratchet. That’s what you need. It’s called spark plug socket.
Shahzao
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Mar 18, 2024
Shahzao
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
539
Points
14
The spark plugs on Yamaha Maxim XJ700 most likely use an 18mm socket, but in some cases a 16mm socket might be needed. It's always a good idea to double-check the size before starting work.
Simon Atkinson
Level 3:
  • Yamaha Master 3,940 Answers
Simon Atkinson
Yamaha Master
Level 3:
Answers
3940
Questions
14
Helped
1071888
Points
14110
The socket is an 18mm Sparkplug Socket for a 12mm thread plug.
4 Related Answers
Rauben Rib Creed
  • Posted on Mar 12, 2009
SOURCE: 1985 Yamaha XJ700 Maxim won't work
All engines need the same three to four things to work correctly..
Compression, Fuel, Spark, (timing).... But, usually those bikes, have fuel issues. The fuel tank spigot has a vacuum controlled valve which when the engine is cranked, suction is applied and fuel then can flow. Second,, the needle and float in the carb tend to get gummed up along with the main and idle jet... You need to make sure the carb is maticulously clean, Using carb cleaner, and tag wire,, or a piece of fine wire ( be careful not to enlarge the tiny holes). Keep refering to the 3-4 list fuel, compression, Spark,,,timing.....
Good luck...!!
Rib
Anonymous
  • 8 Answers
  • Posted on Jul 04, 2009
SOURCE: 1985 Yamaha xj700 Maxim- Carb. fuel lines
yes, the breather line hooks to the petcock on the line facing the back, the fuel line hooks to the larger one. the line from the breather is actually a vacume line that turns on the fuel, without it you will not get fuel out of the petcock unless it is in the prime position.
Harald
  • 15 Answers
  • Posted on Mar 24, 2010
SOURCE: Carburetor on yamaha xj700 maxim x
Actually, they're not Hitachi carbs. Since you have a 1985 "Maxim-X", the model number is actually XJ700XN. The XJ700 does indeed have Hitachi carbs but your bike, the XJ700XN Maxim-X has BS33 Mikuni carbs.
Careful with the model number, the XJ700 and the XJ700X are entirely different bikes.
By the way, if you want more answers about your Maxim-X, feel free to visit the "Maximum Maxim-X" web site at www.maxim-x.com and the lesser known FTP site for the Maximum Maxim-X web site at www.maxim-x.com/pix
HAP
Anonymous
  • 17 Answers
  • Posted on Feb 09, 2011
SOURCE: what is the size of the socket to remove the spark
Should be 5/8 or 6mm.
What is the size of a 1985 Yamaha XJ700 Maxim Oil pan drain plug?
Are you wanting the size of the hex bolt head or the thread size and bolt length? Most oil pan plug bolts are either 17mm (5/8th socket) or 19mm (3/4" socket) bolt heads.
How to reinstall my xj700 maxim exhaust
Courtney, I will add exhaust schematic link for xj700 maxim exhaust, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Exhaust schematic Yamaha Xj700 Maxim 1985 Usa
changing exhausts on 1985 xj700 maxim help
84 85 XJ 700 YAMAHA MAXIM FACTORY SERVICE REPAIR MANUAL motorcycle parts...
Aug 23, 2016 • Motorcycles
4helpful
2answers
HAP
2helpful
1985 Yamaha Maxim XJ700 not starting
It seems the float chamber of the carbs are not getting enough fuel (gas).
Try to check this first by opening the carburator float chamber drain screws....thn select the petcock to 'prime' positon and see if theres fuel running out of those drain screws freely.If not thn it time to clean the carbs.
Not bad too to remove the spark plugs and clean them and regap.
Hope this helps!
2helpful
2answers
Good luck...!!
Rib
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
