It has been 2 1/2 weeks since this was posted so it has already been solved probably. Open the basket on the pump to see if the water is draining freely from the wash tub. (You can access the basket by removing the round panel in the lower right corner of the front panel). If the water is freely draining, check for plugging of the drain line from the pump to the outside. If the water is not freely draining, remove the rubber boot between the wash tub and the pump and clean out the debris around the ball at the wash tub end.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch WFMC2100UC WFMC 2100 UC
There is water leaking from the front of my Bosch Nexxt Essence washer. It is not coming from the...
(More)
There is water leaking from the front of my Bosch Nexxt Essence washer. It is not coming from the back just the front edge?
It rarely get's past 52 minute point (Regular/Cotton cycle), simply stops and even though the door...
(More)
It rarely get's past 52 minute point (Regular/Cotton cycle), simply stops and even though the door locked indicator is still lit, the door can still be easily opened. It begins pumping water out in the first minute even after the repairman replaced the pressure switch. At first the repairman thought it was acting up because we were using too much detergent even though we were going by what the manual recommends. The repairman said Bosch is rewriting it's manuals recommending only a teaspon of detergent for this and other front load washing machines. We've tried the running cascade dish detergent through it trick to no avail, as well. Before all of this it was running fine with the exception that sometimes we'd have to run it on the handwash drain and spin cycles again because the clothes were still very wet at the end of the cycle. Again, repairman attributed this to too much soap. We also unscrewed the drain access cap that's 5 o'clock to the washer door and it seemed pretty clean. The repairman is quite confounded by it to the point where he said he'd be willing to find someone else to work on it. That's all I can think of. Any suggestions would be mighty appreciated.
It's fine if my Bosch washer and dryer beep once when they're finished, but it's annoying how it...
(More)
It's fine if my Bosch washer and dryer beep once when they're finished, but it's annoying how it keeps beeping if I don't go to it immediately. Is there a way to turn off the beeping so that it isn't so annoying if I'm in the middle of something else when the washing finishes? Thanks!
