Question about Sony FD Trinitron KD-34XS955 34" TV
Sony TV keeps flipping to Memory Stick screen by itself
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV? your problem in system control section check aft &tuning ckt &its voltages check for loose contact in above ckt check tuner thanks
Posted on Sep 10, 2007
SOURCE:
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick pro duo reading problem
Usually that means there is a problem with the memory stick itself. Try replacing or buying a new memory stick
May 09, 2010 | Sony PlayStation Portable (PSP) Console
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
It keeps saying on the lcd memory stick error!
remove the memory stick, you should be able to see the backend of the stick, push it in and it will pop out. after removing the stick try operating the camera again.
Oct 27, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Flash memory card - 2 GB Memory Stick PRO My memory stick board was bent and now it does not detect. Can the flash memory chip be removed and then soldered on to another working Sony memory stick? if...
very difficult to retrive mem. cannot be soldered due to the traces are microscopic and an iron would go through multiple traces. try putting in cpu rather than cam to try and save to hd. good luck hope this helps.
Jun 04, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Sony FD Trinitron KD-34XS955 34" TV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
