have just repaced fan oven ellement on smeg a42 range main oven and all has been well for last two days. turned oven on today and after 5 mins cloud of smoke apeared over cooker. pulled back of and no apperant fire damageg but when switched back on main oven fan does not work? olso the main oven cooling fan has been playing up would this affect any thing? smeg charge 65 p/h so any help
-   I turn the oven on and an electric smell and some smoke coming from behind the oven. Pulled out oven and coming from vent behind control panel. Doesn't happen when the burniers are on...only oven. Same model 5 years old. -   cschrage
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out
if i have helped rate me
work with safety all the time, unplug at all times when working on any item
I have to replace an Lg range(under two years old) because the thing is basically junk. The controls...
(More)
I have to replace an Lg range(under two years old) because the thing is basically junk. The controls work sporadically, have replaced the circuit board three times, and now the enamel is flaking off the oven. Stove need to be free standing electric. I'm looking at Whirlpool Gold(GFE461LV) or KitchenAid Architect II Kers807S....I'm really worried about getting another problematic stove. What should I buy????
My st george grillmaster oven is not working, I suspect it is something to do with the automatic...
(More)
My st george grillmaster oven is not working, I suspect it is something to do with the automatic timer switch, could that be correct?
How to wire Bake or broil element red and black wiring in back of the stove Install new Electric Ge...
(More)
How to wire Bake or broil element red and black wiring in back of the stove Install new Electric Ge Element forgot what color wiring goes where red on my right side and black on the left When install all the power went out, what wrong
The stove burners started to spark with no one using the stove. When the knobs are turned to...
(More)
The stove burners started to spark with no one using the stove. When the knobs are turned to "light" the spark timing speeds up. Range work OK other than the continual sparking @ 5/second.
