Back to:
Tags:
Car Speakers and Subwoofers
Generic problem for all Car Speakers and Subwoofers
Low level noise causing sub flutter
posted by sensi on Sep 09, 2007
I have an 02 alero. I have installed vega subs and an amp. I have managed to get power and tunes but when the radio is at zero the subs have low level engine noise and the subs sit there and flutter. Increasing the volume drowns it out but increasing the bass boost just causes the flutter to worsen.
All cable have been changed and I have even tried a new amp in the event it was an internal ground problem but with no success.
How do I get rid of the flutter and engine noise?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 24, 2008
Not Rated (0)
audiowizard
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
try earthing the outer part of the connection of the phono lead. its likely the earth tracker has gone in your headunit
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on low level noise causing sub flutter:
I don't want to Accept this solution
Solution #2
posted on May 17, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
fukin sell the ****
Thank You!
Solution #3
posted on Dec 09, 2007
Not Rated (0)
toddwm
Rating: 100%, 1 votes
Power wires and sound cables running close together can cause this problem. Separate them.
Thank You!
Solution #4
posted on Oct 20, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
install a DC passing and AC blocking inductor inline with the input of your sterio, or install an AC shorting cap in parallel with the DC power input of your sterio. It is being passed from the sterio to the amp and then amplified in the amp.
Thank You!
Solution #5
posted on Oct 12, 2007
Not Rated (0)
gmaninfinite
Rating: 85%, 2 votes
the ground may not be coming from your stereo it should be coming from a loose wire under the hood. Do u have the factory radio? that might be it if u do
Thank You!
Can you Help with these Car Speakers and Subwoofers problems?
cd changer not playing keeps coming up check disk 4 even...
y don`t now acsees cod of my radio caset
i have just bought an audi a4 and the radio is displaying...
Bought a used Honda and the car stereo needs a code!
i locked my kenwood kdc mp338 when i unhooked my battery...
Loading problems.
Repair Service
Find Car Speaker and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
