Question about Hitachi 50EX01B 50" Rear Projection Television
Protection Screen How do I get the Protection Screen off of the TV? (I have bug that has gotten behind it some how??)
  • bhoffman Sep 09, 2007
    I have a clear protection screen over the screen.
    The bug is not on the tub...I need to know how to get the Clear Protection screen off the front of the TV?
    Sergeant:
    Champion:
  • 375 Answers
If your can see the bug chances are its either on the crt lenses or on the tube assy,remove rear panel and inspect to see if the tube can be cleaned with a dampend cloth make sue the set is off.
Posted on Sep 09, 2007
  • Anonymous Sep 10, 2007
    run you fingers anound the sides of the screen and see f there are inserts that can be remoned if not you must remove upper section of screen for rear,(scews) pay attention to control buttons and harnesses mounted at the front,also try removing the lower front panel first to see if ther are any hidden screws that need to be removed .ps if your gona handle the screen assy put on a pair of latex gloves to prevent finger prints on inner screen.
SOURCE:
Why do i have dark smudges on my tv
Usually that is actually dust that has gotten in behind the lcd screen.The dust congregates on top of the tv and eventually falls in through the air grids. Im not to sure how to rectify this without opening the tv up not something I would recommend and can break your warranty.
Jan 06, 2015 | Televison & Video
My Mitsubishi TV has a small white dot on the screen
This could be something on the lens or mirrors. you can open one or both porthole covers on the left or right side of TV to determine if this is the cause. You can look at the mirrors & lens to determine if a bug or dust has gotten on either part. Then clean.
HOWEVER, the most likely cause is the DLP chip. this causes white & or black dots. May start out as one or two, then multiply.
See the following website for the proper DLP chip for your Mitsubishi model#:
http://www.shopjimmy.com/catalogsearch/result/index/?cat=24&q=dlp+chip
Jul 09, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a 60" sony projection TV (2005 mod.). I need to know how to take off the front screen (glass) of the TV so I can clean the inside that has gotten dusty.
U can't take out screen,it screws in as part of the LCD screen.Just take a soft cotton cloth,soap it with some water rinse it,gently clean ur LCD screen.
Apr 01, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
An insect has gotten inside the television and is throwing a shadow on the screen
This is not the easiest set to get into where you could clean out behind the screen. I would suggest having a technician look at it to save from damaging the TV.
Oct 17, 2009 | Sony KDS-R70XBR2 70" Television
Bug behind plastic screen cover and loose right side movement
Sadly the entire system needs to be taken apart. There is going to be at least 15 screws to remove and you need to move with surgical precision.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 14, 2009 | HP Mini 1035NR Notebook
Front screen
look on back of tv there is 25 screws remove them and the 5 on bootom in front of tv.
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
Monitor strip down got a bug dead on inside of my screen
HOW CAN I REMOVE THE PROTECTION SCREEN TO CLEAN A DEAD BUG BETWEEN DE PROTECTOR AND SCREEN TV
Aug 11, 2008 | RCA HD52W59 HDTV Projection Television
Tv protection screen
if you remove backing you can reach in and up if your small enuff and clean without taking it off but if you want to take i suggest getting another pair of hands or 2 and while their holding screen you take off screws directly behind screen
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
Hitachi 50EX01B 50" Rear Projection Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
