Fresh rebuild on piston & sleeve. Compressor comes on and runs for a minute or so, then kicks off for about 10 sec, then on for 10 sec, etc..... Builds pressure when running, but doesn't stay running long enough. Is there some type of thermal cutoff or something?
SOURCE: compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
SOURCE: Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
SOURCE: compressor runs fine builds up pressure then will
PRESSURE SWITCH IS BAD. NOT ADJUSTED CORRECTLY, POINTS ARE STUCK/WELDED TOGETHER OR THE NIPPLE UNDER IT IS CLOGGED. DRAIN PRESSURE AND REMOVE PRESSURE SWITCH. KNOW YOUR UNITS PSI AND TAKE THE SWITCH WITH YOU TO MATCH. IF YOU WANT TO INVESTIGATE FURTHER BEFORE YOU BUY, LOOK IN THE SIDE OF THE SWITCH AND YOU WILL SEE THE POINTS. THEY SHOULD BE TOUCHING WHEN ITS SUPPOSED TO RUN AND SEPERATED WHEN ITS SUPPOSED TO CUT OFF. HOPE THIS HELPS, JODY
SOURCE: ingersoll rand compressor T30 model 7100
I would wonder A if the wiring was heavey enough to carry that sort of load with out overheating B if the motor is big enough to do it for the same reason( ?what is the duty cycle?) C if the receiver is big enough to allow reasonable time between shut down and start up --- remembering that at start up the motor pulls double the current to start up and if it doesn `thave sufficient time to cool alittle before being called on to do it again and that would prompt the question ,does it have sufficient ventilation? these are all queries that would need addressing before I would try to offer a solution ,one thing is certain ,--there is something wrong
