Freezers
Problem for Freezers
Generic problem for all Freezers
Fridge not COOLING
By paidin on Sep 09, 2007
whirlpool fridge not cooling ,defrosted, light still on
Same Problem
Jul 20, 2008
-   Maytag refrigerator has snow on evaporator coils, limited cooling in freezer section, unit will not get cold enough to freeze water.
Was having water droplets around freezer door, but it has not been leaking lately.
I have replaced the defrost thermostat, cleaned the coils at lower rear of unit, and have tested the heating tube for continuity. -   mcolthompson
Jun 03, 2008
-   freezer not freezing-   Guest
Feb 19, 2008
-   I moved the power cord to a new plug and a few days later noticed problems. i checked the power and am getting 124 hot to neutral and hot to ground so I feel that it's not a power problem. the compressor runs (seems not to shut off) and at times it cools (when set to 7 down to almost 0 F) then over night warms up to 34 degrees and there's water drops on the inside vice frost. it's a june 2004 model mqc1557aew. hate to junk it but I can't afford to give all my food away when it decides to thaw out. any suggestions on testing or replacement of parts? the liquid and suction lines are a bit cold and slightly warm but I expected a bit more in terms of temp of each line. should the liquid line have condensation in a humid area? Mine doesn't. Thanks for the help. -   sorenson
Best Solution
posted on Sep 20, 2007
Helpful)
dididsaythat
Rank: Wiz
Rating: 84%, 521 votes
what u mean by defrosted? was the evap. coils all frosted up ..looks like snow there?
Was this helpful?
Yes
No
Popular Solutions for Freezers
Questions and Unsolved Problems for Freezers
Answer
I'm looking for an upright frost free freezer in white with between 16 and 20 cu ft and temperature... (More)
Answer
defrosted my proline freezer now it won't turn on (i did it carefully with hair dryer) Help
Answer
my beko glacier has stopped working, the light still comes on in the fridge so theres still power... (More)
Answer
flashing warning light. door was left open temporarily. light continues to flash red.
Answer
Clicking front display on whirlpool AFG7060 - and does anyone know how to adjust the temperature... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Freezers:
Top Freezer Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Freezer Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
