Question about Clarion ADX5255
Honda Passport '98 compatibility
How do I find out if a certain car stereo unit will fit in my car?? I'm looking to buy on e-bay and there seem to be decent deals, IF they fit. TIA, Dan
  • denverdan Sep 09, 2007
    Thanks. I have space for a double din unit but want to be sure there is not anything else I need to know.
  • 883 Answers
They are sized by a measurement system known as DIN. Yours is either a DIN 1 or a DIN 2, differentiated by the height of opening in dash. Simply put, the DIN 2 is twice as large as a DIN 1. If the opening height is roughly 2-1/2" high, you need a DIN 1 unit. Prior to the DIN rating system, many owners were frustrated over the 'FIT' incompatibility with various widths, depths and heights.
Posted on Sep 09, 2007
  • Marty marty Sep 09, 2007
    no problem, when you install it without fit problems, remember to rate me as solved. The DIN system evolved because of problems like this.
If you meant fuel guage, most likely the sender unit inside the tank has a problem. To test, find the wire going to the sender and ground the wire briefly to see if guage needle goes up. If so, replace sender.
Mar 27, 2015 | 1998 Honda Passport
Check to see if you can see or hear the rear wiper motor running.
If the motor is running you can tighten the bolt, look under the wiper arm pivot point .
If the motor in not running, look under the dash on the drivers side for a blown fuse or bad wiper motor relay.
Hope this helps.
Fuel light on a 98 honda passport flashes
These Isuzu-built vehicles had many problems with fuel system components. Particularly the sending unit in the tank. Note: If the unit is replaced, the PCM must be updated to accept the new pump calibration before it will work.
Mar 17, 2014 | 1998 Honda Passport
What Cain of oil use the Honda Passport 98?
20/50 cheapest you can get and change every 6000miles ,with a oil filter every third oil change
Mar 25, 2010 | 1998 Honda Passport
Can the parts on a 97 isuzu rodeo interchange with a 99 honda passport
No...the 96-97 don't interchange with the 98-00....and even some of the 98 parts (the tranny for instance) don't fit on the 2000.
Type the part into this website
If it only comes up in the 96-97 and not the 99, it won't fit.
Feb 09, 2010 | 1997 Isuzu Rodeo
99 honda passport
The problem is most certainly the fuel level sending unit - not the fuel pump. However the mechanic was right in a sense that if you're going to pay the labor cost to drain and purge the gas tank to replace the sending unit you might as well replace the pump at the same time, since you have to take it off to get to the real problem.
Use your odometer.
Oct 22, 2008 | 1998 Honda Passport
99 honda passport
your sending unit in the gas tank is bad. You most likely already priced a new one that you can only get with a fuel pump. {around 275-300 dolllars}. I found the sending unit by itself on ebay for around 40 dollars. Just go to ebay and type in 98 99 00 01 02 rodeo passport fuel sending unit and that should take you to the guy I'm getting mine from.
Jul 10, 2008 | 1999 Honda Passport
Car Audio & Video Logo
95 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
