Question about Zanussi FLA1001W Front Load Washer
Water not draining from washing machine
We have a zanussi FL1282 that will not always drain. We have cleaned the hoses, which were gunky, and filter trap, which is cleaned frequently and ok. We have attempted to look at the pump but donot know how to get it out. Can the pump be removed for cleaning? Are there any other things we should check and if so how. The machine will work the first wash but then gives up at the point of draining. I then have to drain it through the filter trap door.
  • 244 Answers
The pump can be removed u need to pull the washer out tip it backwards and lean it against the worktop bend down and look undo the washer u will see some 8ml screws to undo once undone u can push backwards and twist the pump out you need to undo the pipes aswell
Posted on Sep 09, 2007
My zanussi washer zwh6160 p stopped working yesterday. It stopped with a load in it. We gad to manually drain it, then git the door open. We cleaned the filter and inlet pipe filter. We switched it on
Considering that machine did not show any error first check that is not activated option "rinse hold" what mean's "stop drum with full of water". I advise you to make a simple test that will show you where the problem is. In the washing machine or somewhere else. Disconnect the drain hose and lift it up to 1m in height and its end hold over the tub or some larger container. Select short drain program and press the start / pause button. If drain hose ejects a solid water stream then is a problem in-house installation of drain water. If does't or poorly drain water then is problem in the washing machine.
Nov 10, 2014 | Zanussi Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
I trust that the drum can be turned by hand.It seems like the filter is blocked you will have to drain the water and remove the filter check that it is clean and the pump is free,with filter out put to spin or drain and see that the pump blade is spinning if not then something is jammed in pump try to free and then replace filter and check for leaks.Check also drain hose not kinked or drain blocked.Hope this helps.
Apr 28, 2010 | Zanussi ZWF1630 Front Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Error message on washing machine E20
E20 is "A problem with water draining"
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
Washing machine
there is something caught in the hose's going on the filter,or something in the pump,drain water again lay machine down on its side,so you.................................can see what you are doing remove and check all hose's,for sock or the like that,happy Chrismas Ire!!!
Dec 24, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi FLA1001W Front Load Washer Logo
148 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
