Question about Canon PIXMA MP830 All-In-One InkJet Printer
WILL NOT PRINT CD DISCS
After six months with no problem printing cds, I put a cd in the carrier, and place it in the slot. The machine take's the carrier into the machine, pauses, then spits it out without printing. Have tried cleaning etc and different discs but to no avail. Any ideas please?
    Sergeant:
  • 390 Answers
You could try uninsatlling it completely and reinstalling it again with printer driver disc.
Posted on Sep 09, 2007
SOURCE:
I have a CD digital clock radio under the counter model number W375 - K every time I put a CD in the CD drive slot it'll go in and return immediately exit immediately what could be causing this
This is the CD not being recognised. It can be that you are not using proper commercially made CDs. It can be that the CDs are dirty or scratched. Finally, the optics in the unit might be dirty, especially if it is in a kitchen! You can buy CD cleaner discs which have little brushes.
May 19, 2018 | The Audio Players & Recorders
Why does my Porche Cayenne six disc changer not recognise two of the CDs?
I have looked into this and can see no reason why The WHO would not play. My theory was that the album was not a pure CD but a mixed format disc. Some disks have a hidden track at the beginning which a computer can read but an audio CD play will skip. I thought perhaps your CD changer was getting confused. However Amazon say it's an Audio CD.
Dec 29, 2014 | Car Audio & Video
How do you load cd's in a six cd player on a 2001 ford taurus ses style
open the cassette draw and remove the cd carrier then place the cd's in each slot ,replace the carrier job done
May 06, 2014 | Cars & Trucks
Can not print direct to cd dvd
  1. Find a printer that prints directly on a CD; this is becoming a popular feature and these printers are getting more affordable.
  2. Step 2 Buy some printable media. Printable media is a bit harder to find and a bit more expensive but you need a special surface that will absorb the ink. They will be marketed as "inkjet printable" discs. Look for them online or at your electronics store.
  3. Step 3 Set up your printer for CD-R printing. Chances are your printer can print on paper and CDs, so you'll have to let your printer know what you are up to. In your printer properties, select CD or DVD as your media type. You can do this from the print dialog right before you print.
  4. Step 4 Clean the rollers. You can do this by running a clean sheet of paper through the printer without printing anything. Load up several sheets of paper and press the cancel button to feed it through. Do this a couple times.
  5. Step 5 Pull out the tray. This may be a separate part of your printer or built-in. Read the manual and learn how to pull it out properly before you go yanking at random and breaking things.
  6. Step 6 Place the CD in the tray. Make sure there is no dust or paper scraps on the tray and place the CD on the tray so it lies flat and the printable side is facing up. For smaller CDs, place the adapter first and then put the CD down.
  7. Step 7 Insert the CD tray into the printer. If the tray was attached to the printer, put it back where it came from. For separate trays you may need to wait until you are ready to print and load it into the manual feed.
  8. Step 8 Design your label. Your printer will have come with label designing software. Take some time. Make it pretty.
  9. Step 9 Print. Double check your print settings and print directly onto your CD. Choose "File" then "Print" and click "Okay." If you are loading manually, now is the time. Manual loading slots are usually on the back.
  10. Step 10 Allow your CD to dry. It is recommended to let it sit for 24 hours. There is a lot of ink on there and you do not want to ruin it with smudges.
May 10, 2010 | HP Photosmart Premium C309A All-In-One...
I have Print Master Platinum 15- 5 CDs only - no paperwork
The install is pretty straight forward. Just start with disc one or disc labeled install cd (or similar) The manual is just guidance and not needed unless you prefer to reference to it. If you do need it you can visit the support section of the Print Master website to download a new copy.
Thanks Live-Tech 1-888-361-8511
http://www.mylive-tech.com
Jan 29, 2010 | Broderbund PrintMaster Platinum 15 Full...
Wurlitzer cd 1015 has 100 cd's and sixty slots for cards ? is there a computer program that prints cards.
a program by LowProfile software prints the cards on A4 paper, including the option to print 'double' cards. (2 CDs on one title card).
The way to do it for 100 Cds is 20 single and 40 double.
Jul 29, 2009 | Wurlitzer Jukebox 1015 One More Time...
CDs won't go in the front anymore.
Im afraid it sounds like that when you put it back together you must not have alligned the slot properly with the drive. Best advice is to take it to your local bose support centre and see if they can repair it for you under warranty - but dont tell them you opened it up or this will void any warrant you may have!
Apr 10, 2009 | Bose Wave Radio
Microboards DX 2 DVD Publisher
May just be the type or mil/thickness of the labels on the cds. Try buying stick on labels and and putting them on prior to burning. They are only $6 at walmart for 20. This will tell you if it is an internal issue or if it is a mil issue
Dec 13, 2008 | MicroBoards DX2 CD 52x Publisher (E01024)...
Epson rx560 won't align to print on cds properly anymore
you can download the latest driver from here http://driverscollection.com/?H=Stylus%20Photo%20RX560&By=Epson click the link directly and select your operating system.
Sep 30, 2008 | Epson Stylus RX560 All-In-One InkJet Photo...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
73 people viewed this question
Clive
Clive
old marine
old marine
Ekse
