Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
USP-porti doesn't find the external hard disk - occasionally
I have a Seagate 500GB external hard disk. Just half an hour ago it worked just fine. I did some changes (on iTunes) to my music and suddenly my computer tells me it doesn't recognise the disk. I checked the status of the port and in says no driver installed. But I just had it... what happened? This is not the first time. Turning the computer off and on doesn't help. Neither does changing the port. Please, can you help? I don't understand much about computers, so keep it simple, please. BTW, the product, I'm not sure if it says Pro in it, on the bottom of the disk is says only FreeAgent desktop 500 GB
  • KristaK Oct 17, 2007
    Problem figured out. Even the slightest movement of the cables will disconnect it. Then I have to turn the computer off, pull the cable out, put it back and turn the computer on. Of course, this happens fairly often, but I can handle it.
    Thanks jackboy for your advice, it made me try stuff and not give up.
  • KristaK Dec 25, 2007
    And one more thing. The external hard disk seems to overheat. An hour power off and it works fine - every time.
I have a Seagate Freeagent 500GB that has been working like magic for almost 3 months.  Suddenly Windows XP pops up a msg that says it can't write to the drive.  Rebooting failed to resolve and now the drive cannot be seen.  The drive power on/off is driven by the USB connection.  USB or internal drive problems will prevent the drive from powering on or off.  I put my drive in the refrigerator for 30 minutes and then was able to get my data off.  My replacement will be a Western Digital!
Posted on Oct 17, 2007
  • 2,985 Answers
If it has been working and now does not not. If the system is ME or NTFS[XP /2000/VISTA] If the port check shows nothing untoward Then you must look to the the disc or its connection or power supply. So -if you can check out the power supply Is it self powered[internally of via a 'power brick'] or does it rely on USB power from the computer? If the latter- disable/unplug some other other USB devices. If it 'works on its own power' check that it is indeed running. Change the USB cable for another. Comeback if still in trouble
Posted on Sep 10, 2007
Can a Seagate External Hard Drive be reformatted?
Yes you can.
Insert the external hard drive into the USB port click on My Computer then right click on the external hard drive and select Format.
Apr 01, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard disk
As you are a seagate user so it would be advisable to try using this software to recover seagate sata hard drive. Just download it online for free trial.
May 22, 2012 | Seagate ST3500418AS 500GB 7200RPM SATA...
I have a Seagate expansion external hard drive, i can connect it, but how do i use it-keep it simple
Put all your documents in my documents folder of your hard disk
or install the software come along with him CEEDO in the hard disk itself.
Always connect both the USP prot of the cale to the PC for better efficiency
Jan 15, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
I purchased a 500GB Seagate external desktop drive about 2 months ago to use it with my mac. I had about half of the capacity used, and today noticed that at least 40GB of avi files is missing. They were...
the easiest option is to fragment your hard drive and try to add it on a different computer to check if it has any errors incurring on it. run disk check utility. if that does not work too, better consult the outlet you bought it from and ask for a warantee if it still has.
get back to me if that did not work and we could try to find other alternatives.
thank you
Sep 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
best buy
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
206 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
