Question about Dell Latitude C640 Notebook
Bought second hand c640
When i boot it up a white screen comes up saying the the device in the system modular bay cannot be identified. It may not be completely inserted...... and the same when i press off or esc key what do i do?
    President:
  • 317 Answers
It's probably your hard drive or cd-rom drive not inserted correctly. Remove each of them, then re-install. For the hard drive: there will be a square compartment under the laptop, remove it with a screwdriver, the drive is square and metal. It should slide one way. Slide it out completely, then re-insert it. The CD drive: there should be a screw about 6 inches from the middle of the cd drive door on the bottom of the laptop. If you remove this screw, you should be able to pull the drive out. Do this, then re-insert it. Only do this part if what you tried with the hard drive doesn't work.
Posted on Sep 09, 2007
  • 883 Answers
Power off even it it takes a battery removal. Now check modular bays and remove then fully insert each device and retry power up. If same results, try repeating above with one of the modular devices removed.
SOURCE:
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
When the machine is powered on it displays an error on a grey screen saying the divice in the system bay cannot be identified, it may not be properly inserted or may have some errors, option 1 press...
Damn i have exactly same problem. i bought a new DVD writer and slided the same into the media bay. But now when i try to boot up i am getting the grey screen with 3 options.
Thanks in Advance.
Sudesh
Feb 18, 2011 | Dell Latitude D600 Notebook
Hello Need help I get error below and don't
one of the devices connected to your MB isn't connected properly.
try to remove them and then to install it again
Nov 14, 2009 | Dell Inspiron 2200 Notebook
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
[email protected]
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Jan 28, 2009 | Dell Inspiron 2200 Notebook
I need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Dec 04, 2008 | Dell Inspiron 2200 Notebook
It won't boot to the os
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Jul 29, 2008 | Dell Latitude D600 Notebook
This screen comes up when it is turned on: "The device in the system modular bay cannot be identified, etc.
I had the same problem.  I took out the optical drive, and powered it on, and it worked.  I may have to purchase a new optical drive?
May 22, 2008 | Dell Inspiron B120 Notebook
Dell Latitude C640 Notebook Logo
486 people viewed this question
Ekse
Clive
Clive
