Question about Dryers
Dryer doesnt shut off
Our electric dryer doesn't shut off unless door is opened up ---- which means our electric bill has skyrocketed as most times its forgotten about ---- how can this be fixed?
  • grandmafix Feb 18, 2008
    Dryer will heat and dry clothes but continues to work for over an hour. We check all the heat limiter but it continues to do the same thing. I am afraid that we are going to need the timing device but where do we get. These stackable commercial dryers were purchase at an outlet store wiithout any manuals. Help!!!
  • c141trashhau Sep 05, 2008
    same problem here. I ordered and installed a new timer module ($117) and that didn't fix the problem.
  • 60 Answers
Check to see if you have 220 volts comming to the dryer in the fuse panel one fuse runs the heat and one runs the motor/timer and if one is blown it can make the dryer run on let me know if this works
Posted on Sep 12, 2007
  • 883 Answers
Does it appear that the timer is advancing? Try a new timer if not.
Posted on Sep 09, 2007
  • Marty marty Sep 12, 2007
    is your timer a mechanical type or is it digital display?...is it working?
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Maytag Neptune dryer displays 88 and won't start
our dryer just keeps running and doesnt not shut off after cycle is done. You have to unplug or open door for it to shut off. This is not a refurbished dryer we had bought brand new
Dec 30, 2013 | Maytag MDE2400AYW Neptune Electric Dryer
My Fisher and Paykel Dryer wont spin... The lights will turn on and press start and it makes a noise like it wants to spin, but it doesnt... the last few times I had to mannually move the inside around,...
This usually means that your belt is broken once you replace the belt in the dryer it should turn the electric motor in the dryer and you should be fine
Feb 07, 2018 | Dryers
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Humming sound an wont dry
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 19, 2009 | Roper RES7646KQ Electric Dryer
My dryer is not shutting off/no heat
The cycle timer motor is bad. Easily replaced and you can do it yourself. Does the dryer normally heat when drying?
Sep 14, 2009 | Zanussi TD4212W Electric Dryer
Kenmore series 80 was working. opened the door to check on
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Dryers
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
164 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
