Question about SanDisk Sansa e260 MP3 Player
Format Ok, i have a sansa E260R and im trying to format it because when i turn it on it just freezes at the second loading screen. Ive tried the sandisk format program and it always says "Uable to view version code" or somthing like that. Help please?!?!
  • himkak Feb 07, 2008
    I am having a sansa e260, i am not able to format it. How can i do that?
  • 626 Answers
The error is because, that program only works with the non-Rhapsody versions. You need to manually create a format text document. It rather lengthy to explain the steps. If you call technical support they can send it to you. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Sep 10, 2007
SOURCE:
Sandisk sansa e260r
if you still have the software that came with it (and installed) plug your sansa into your computer....the software should recognize it...then look for a button that says "repair" or "format" im not familiar with the exact program but i know your problem all too well...*shudder* what that will do is it will REMOVE all the songs from the sansa...but if their still on your computer you should be fine...then it reinstalls the firmware(the codes and software that make it work) then you just have to re-addall your music and your all set :) if this doesnt work feel free to repost here :P
Feb 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e270 synchronizing problem
It might be a device certificate error..what you will need to do is to format the device..Keep in mind that formatting the device will delete all the songs you have in there..to format click menu,settings and then click on format..if that doesnt work you will have to update the firmware on the device...Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
I hope that helps
Thank you
Computerrep
Aug 19, 2008 | SanDisk Sansa e200 MP3 Player
My Mp3 player keeps turning on repeatedly
Try unscrewing the back and taking the battery out for a minute and replace and see if that helps.
Aug 07, 2008 | SanDisk Sansa e250 MP3 Player
Hey
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 18, 2008 | SanDisk Sansa e200 MP3 Player
My sansa wont let me always shuts off
The cleanest way is to start from scratch. Format the drive and reload.
Mar 16, 2008 | SanDisk Sansa e250 MP3 Player
Won't let me put movies on it
the format of the movie is not media player or quick time
Feb 21, 2008 | SanDisk Sansa e260 MP3 Player
My sansa wont boot up
Re - Format Your sansa drive
Dec 13, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e250 freezes!
This should take care of it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260R
Go to best buy.com then under music & movies click music then put vou mouse arrow on digital music then click Best Buy Digital Music Store then click Access to unlimited music › then there u go create ur account
Jun 02, 2007 | SanDisk Sansa e260 MP3 Player
Sansa mp3 player freezes at refresh database
The Same thing happened to Me once. All you have to do is reformat it. You can do this by first putting the player in recovery mode. You can do this by putting the hold button on the side where you can see the orange and then plug the device into the computer while holding the power/Menu button. Then go to my computer to Verify that it came up as 16MB-Format. Then you can type into the address bar and type in http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip. then once you do that right click on the file you downloaded and select open with compressed folder and drop and drag to the 16MB-Format drive. In the 16MB-Format drive folder select file menu and select New - Folder and rename it sansa.fmt then press enter to save. Finally move the hold switch back and disconnect the device and look at the screen and verify it is formatting and resetting once it's done and finishes the updates restart and if needed pick your language. check and see if you can use your player.
Mar 26, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
