Question about Canon imageRUNNER 400S Copier
Canon ir 8500
Sir,i have an error E010& E065 both in ir 8500 piz give me solution
  • 1 more comment
  • mada Jul 20, 2011
    code 532
  • Anonymous Mar 14, 2014
  • Anonymous Mar 22, 2014
  • 62 Answers
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Posted on Sep 11, 2007
Errar no 111
Posted on May 04, 2008
My canon ir 7105 show E065 , i change the primary charger assembly still the same plz help me
E065 if you already change primary corona assy and the problem is the relay pcb , you can found it in the lower left side of the machine, i encountered it twice check if the fusible resistor is busted , if faulty u can jumper it using wire.
Apr 02, 2012 | Office Equipment & Supplies
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Ir 8500 cannnon copier black shade on paper
hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
May 16, 2010 | Canon imageRUNNER 8500 Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Apr 15, 2009 | Canon Office Equipment & Supplies
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
Dec 25, 2008 | Canon imageRUNNER 8500 Copier
Ir 220
E010 codes relate to the main motor or 24v supply through the interlock system. Check for binding in the main drive, or loss of drive voltage.
Aug 26, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
329 people viewed this question
old marine
old marine
