Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Registering msdatlst.ocx and msdatrep.ocx in Vista
I am just not able to register these in Vista. I have tried switching UAC off and then unregistering / registering using regsvr32 but no dice. This is driving me crazy since nothing seems to work. I wish to use these controls on a VB 6 form. Can someone help? Thanks.
  • 3 Answers
This may help to find the reason why msdatrep.ocx is not registering. Try http://www.dependencywalker.com/ download, run it and tell it to be associated with .ocx files too. Than you can right mouse click on msdatrep.ocx and say "View Dependencies" - any missing dlls will be in red. This may help to find the reason why regsvr32 is not working.
Posted on Sep 09, 2007
SOURCE:
Comdlg32.ocx
You didn't provide a question, but I can offer this:
Re-Register the file:
You can Re-register this file it by typing "regsvr32 comctl32.ocx" from the command line in the system32 directory.
Perform the following steps to make the changes:
1. Click Start
2. In the Search bar type CMD
3. In the programs pane right click on cmd and "run as an Administrator"
4. Put in your credentials for UAC prompt
5. In the command prompt type in "regsvr32 comctl32.ocx" then press ENTER
Oct 22, 2013 | Burton Tsang Key Presser
Tip
How to Register DLL files
On Microsoft Window's operating systems, a DLL stands for Dynamic Link Library. DLL's are relatively small files that include a library of functions- usually data that can be shared across multiple applications. DLL's are called upon by various applications and can be loaded and utilized by these applications concurrently.
Registering a DLL
There are two easy ways that a DLL can be registered in your Window's operating system's registry, the first is the simplest, known as self registering files, the second way is to manually register a DLL.
Self Registering Files
It should be noted that many DLL files are self registering, they include information required to store themselves in the operating system's registry. As the name states, self registering files require no human intervention. Self registering files will automatically store themselves on your machine and become accessible when needed. Besides DLL files, other types of files that are sometimes self registering include .EXE and .OCX.
Manually Register Files
The second method used to register DLL files on your computer is via manual registration. Manually registering a DLL file is quite simple and can be done in only a few steps.
1. The first step is turn on your computer, launching your Window's operating system.
2. Once your Window's operating system has loaded completely, click on Start and then click on Run.
4. Once the command is input into the Run field correctly, press Enter.
5. Once the DLL has been registered, you should receive a confirmation in the form of a pop up box. This message will list your newly registered DLL file and confirm that is was successfully registered into the registry.
on Aug 28, 2010 | Computers & Internet
Tip
Remove prompt when running applicaiton in Vista / Windows 7
Are you annoyed by these notification every time you open installer and system applications?
That is the one called UAC in Vista, Windows Server 2008 and Windows 7.
What is UAC?
-User Account Control (UAC) is a technology and security infrastructure introduced with Microsoft's Windows Vista and Windows Server 2008 operating system. It aims to improve the security of Microsoft Windows by limiting application software to standard user privileges until an administrator authorizes an increase etc etc etc. Who the heck wants the definition? ^^
The simplest way to define this one is
- The Annoying prompt on Windows Vista / Windows 7 that makes your PC slow.
It is also an idiot proof application that will give you just a minimal security.
How to disable it?
1. Go to Control Panel
2. Switch to Classic View / Small Icons View (inWindows 7)
3. Click User Accounts
4. Click Change User Account Settings
5.a (Vista) Unchecked the box then
5.b (Windows 7) Scroll the Scroll bar to never
6. Click OK/Next
7. Restart your computer.
After restart, you will the difference of the speed of your computer.
Try it! hope this Tip Helps. ^^
on Jan 24, 2010 | Computers & Internet
Do you have to register the laptop?
Only if you want to be kept up to date with support and driver downloads from Gateway (that is if you are referring to registering with the manufacturer and not Registering the Windows OS.
Jan 12, 2011 | Gateway Computers & Internet
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Vista not recognizing driver from usb g220
Try turning off the Vista security feature known as User Account Control (UAC).
Go into Control Panel/Users. Select your own account then click the link on the left "turn UAC on or off". Disable UAC then click Apply/OK.
Now try installing the driver again. If you still get the "digital signature" warning choose the option to "install anyway".
The driver should then load. You would be best advised to re-enable UAC after you have finished loading the driver.
Jan 03, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
662 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
