Question about Everex StepNote VA4103M Notebook
No sound from speakers, only headphones
I've had my Stepnote for about 6 months. All of a sudden I cannot get any sound to come out from my speaker. Not mp3 files on WinAmp, not computer alert sounds, not audio from embedded video on websites. The sound does work, however, if I have headphones plugged in. I'm afraid it may be a hardware problem with the headphone jack itself. I tried updating my audio driver, but it said I have the most current one.
  • 198 Answers
Re: no sound from speakers, only headphones
Hello, You will probably need to dissasemble your laptop and check both the jack output and the speaker wires. You noticed that when you insert a headphone the internal speakers are muted automatically. This is due to a mechanical contact in the audio output jack. Therefore the jack itself needs to be checked (replaced eventually). If that's not the problem the wires to the speakers may not make a perfect electrical contact. DOn't worry about a more severe hardware fault. If the internal audio amplifier, on wich the speakers are connected, was broken then you woundn't have sound on the headphones either. So in the final the problem is dissasembling the laptop. If you aren't confortable with this, please don't try because a laptop is a fairly complicated device and it's dissasembly can prove difficult even for experienced people. Every laptop model has it's own mechanical make-up so therefore is hard to know them all. If you think you can do this you may contact me on the chat because the process will be complicated and I will need a large amount of feedback from you as the things go by. Otherwise, a service center could do that for you. It shouldn't be an expensive repair, and they should offer warranty for this repair in case you have problems in the future. Sorry for I'm not able to help you further on this way.
Posted on Sep 09, 2007
0 characters
3 Points
How do i fix hp pavilion dv 6 sound problem
I would check the headphone socket is not damaged. If there is a faulty contact, the headphones will still work but the speakers won't.
Feb 16, 2016 | HP Pavilion DV6700T Notebook PC
Sound stopped playing through speaker
Return it for replacement/repair.
Aug 06, 2015 | VIA PC Laptops
Speakers not working but headphone ix ok.
Open volume control - headphone and speakers are a separate control.
Jul 26, 2013 | Dell Inspiron PC Laptops
Only one of my two headphone jacks plays sound
you can use a usb sound device its very cheap 2 $ in value
Feb 02, 2013 | Dell Studio 1737 Laptop
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | PC Laptops
In order for you to resolve this problem you may need to run the software for thsi computer containing the software for the sound card of this computer and that will fix the problem....
Oct 19, 2008 | Everex StepNote NC1500 Notebook
Update driver, goto select OS and choose Audio then VIA HD Audio Codec 1708b. If this does not work, click mute and un-mute ontaskbar when there is no sound. I have had the same problem (sometimes) when using certain headphones,and pausing video, then playing video,sometimes the headphones have no sound, but if I unplugged headphones, the speakers work.I plug headphones back in, no sound. So i press the mute button twice.
Jul 23, 2008 | Everex StepNote NC1500 Notebook
Built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Apr 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Pc speaker
You go through control panel option sounds & audio device there you will get enable speaker option check that one.
Feb 13, 2008 | HP Compaq Presario V2000 Notebook
Headphone not working on the headphone.
Try the headfones through a sterio or something just to see if the headfone itself is not faulty if it is take it back to the shop and get a replacement. Else the socket for the plugin is faulty.
Sep 22, 2007 | Everex StepNote VA4103M Notebook
Everex StepNote VA4103M Notebook Logo
131 people viewed this question
Top Everex PC Laptops Experts
Are you an Everex PC Laptop Expert? Answer questions, earn points and help others
