Question about Fujitsu Plasmavision 42" TV
No power TV will not turn on There appears to be no power to the set?
  • Anonymous Mar 22, 2008
    42 inch plasmavision we moved from one room to another and was unable to get any power to the tv...tv will not turn on and there are no lights on the tv indicating power
    New Friend:
  • 76 Answers
Check horizontal output transister short. Check AC fuse open. If it is open check powersupply section any short circuit and check PTC.
Posted on Sep 09, 2007
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby button (red) flashing on tv. tv turns on briefly(no picture) and then turns off with flashing red light re-appearing.
Try tv unplug,replug about an hour later.The tv now,resetting to factory setting.The tv now,should work.Not than,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 08, 2010 | Sony BRAVIA KDL-40V3000 Television
When TV is off and there is a power outage the TV
This TV has a Power Standby feature (pg. 40 of your manual) which allows you to more quickly turn ON the TV. When power is lost and then restored, your TV will display the HP logo screen while it boots the digital circuits. After it is finished, (unless it was previously turned on) it should appear to be OFF. This is normal operation. If you like, you can change this setting to LOW POWER. At this setting, each time you turn on the TV, you will see the HP Logo screen and picture/sound will appear after 20 seconds. Again, take a look at pg. 40 of your owners manual for more information.
Mar 15, 2010 | HP PL4260N 42 in. Plasma HDTV
My TV remains on standby after following the manual's instruction on turning on the TV. What is the Power Control Setting? And where do I adjust. It appears the TV isn't getting power or I don't know
hi friend,,,
Power Control Setting means nothing that whether the incoming voltage is whether above 240 wats or below it if you have multimeter check it,,,,'
thank u,,,,,,,,
it will be also any burnt resistors problem
May 03, 2009 | Televison & Video
Initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Oct 09, 2007 | Televison & Video
Fujitsu Plasmavision 42" TV Logo
79 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
