Question about EliteGroup Intel Pentium 4 Processor 506&ECS P4M800-M7 Motherboard (506P4M800M7)
Beeping i have a problem with my motherboard(ECS P4M800-M7) i don't know why did the mobo suddenly have 3 long beeps, i just want to reformat my computer because it is now slow, so, i've decided to put the IDE cable on the CDrom and then, after that, after i've restarted the computer without the CDrom, it just suddenly beep..
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things to check/try: 1. Make sure your video card (if using one) and the memories are properly seated to their slots. Do an R & R (remove, reinstall). It might also be a good idea to clean the little gold edge connectors; 2. Reset your CMOS/BIOS by using the onboard jumper near the battery. Restore to original position after reset; 3. Double check your master/slave jumper on both the HD and CD; Hope this be of some idea/help. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 09, 2007
  • Louie  Role
    Louie Role Sep 10, 2007
    Hi again,
    The suggestions posted on Sept 09 Not Helpful?
SOURCE:
ECS MOTHERBOARD NO BOOTING UP
They must have correct ram installed.
Hard to believe all 10 are faulty.....sounds like a ram fault.
Could also be wrong / faulty CPU
Apr 12, 2010 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
ECS Motherboard P4M800 LGA 775 Socket
One of these should work:
1. Reset the BIOS (remove mobo battery or short-out the two reset pins near the battery or CMOS chip)
2. Disconnect every drive from power and data; remove all add-on cards. Leave only video card and one memory module in place. Turn on.
I hope #1 worked for you.
In #2, a device may be internally shorted to ground, that's why you must disconnect the power AND data cables from them.
Sep 24, 2009 | EliteGroup ECS P4M800-M Socket...
Wonder if p4m800-m7 will support the new pentium dual core
For the full list of processors supported on your motherboard, click this link:
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=548&MenuID=69&LanID=0
Hope this answers your query. For more help and clarifications, please reply to this post. Thanks
Aug 31, 2009 | EliteGroup P4M800-M7 Motherboard
Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1 mobo. Cannot do POST. The mobo runs fine with Intel Celeron 326 fine.
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jul 11, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Is P4M800-M7 mobo can support the pc333 sdram memory? Thank you.
Yes, according to the specs that I read the P4M800-M7 (socket 775?) is designed to support pc333.
Only one time I had a problem with an ECS motherboard, I had the correct memory, but the board had a different voltage requirement. Did not cause any issues, other than it didn't work. I don't think that this would be a problem for you though.
Oct 14, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7
please give me a software copy of motherboard P4 M 800 -M7 A ver 7.1
Jul 13, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 no sound
Here is the link :
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=91
Select the one that says "On board Audio". There are two options: one for WIN Vista and the other for Win XP/2000, etc
Cheers,
Lolita
Apr 09, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
