Question about Whirlpool AWZ410 Front Load Washer/Dryer
Drum filling with water
Every couple of days the drum of the washing machine begins filling with water even though it has not been used. I have cleaned out the filter several times but it still keeps happening. The machine works fine in normal use, both washing and drying, and is completely clear of water when the wash cycle finishes. The machine is a couple of years old and has worked fine until recently. The machine has not been moved/altered in over a year.
  • Anonymous Mar 18, 2014
    Drum taking in water but not moving
  • 641 Answers
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Posted on Sep 09, 2007
SOURCE:
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Hotpoint wmud962
bidatw . com the cheapest software you can get!!!!!!!
Jan 17, 2014 | Washing Machines
I have a black hoover VHD 844 DB washing machine and recently after a wash has finished and ive the clothes removed water begins to very slowy fill the drum again. The water isnt smelly but looks dirty....
Your water valve is not closing all they way and either needs to be replaced or cleaned. Even though the video below is on a different washer, it gives you an idea on what is required to be done.
Nov 22, 2017 | Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Washing machine agitates at beginning of cycle without filling
Chances are either:1) the water pressure switch has failed or 2) the hose that connects to the air bell has debris in it and it will not allow the switch to reset
Mar 02, 2009 | Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Washing machine w827 drum fills when the machine is switched off
You have a bad water inlet valve. There is probably silt in it and it is stuck partially open. Replace the valve and you'll be back in business. Hope this helps!
Feb 05, 2009 | Miele Novotronic Premier 500 Front Load...
Whirlpool AWZ410 Front Load Washer/Dryer Logo
310 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
