Question about Lands Phones
Can't register new handsets
I've just bought two new handsets (E1100) to go with the two (E1110) that we already have. I've followed the instructions to register the handsets so that they all work together but it just won't do it.
Any ideas?
Thanks Sarah x
  • s_palk Apr 10, 2009
    Meant to say, it's a eurotel.
  • 55824655 Apr 24, 2009
    Sarah, Maybe you can help me, I have just bought the base set, How do I register them, I chucked the instructions out my mistake.
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
You can register additional handsets to have up to five handsets per base unit,
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING.
If the handset registration is successful, you will hear a confirmation tone and
the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset number.
This handset number is shown in the handset display in standby mode. If the
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Posted on Jul 29, 2010
SOURCE:
My CL80101 will not register, what to do?
1. When the new handset says "Connecting..." and goes
nowhere else, enter *331734 [menu] and it will soon
beep and display "Not registered"
2. To register the new handset to your base: on the base
press the "Handset Locator" button and hold it until the
"in use" light comes on ( ~ 4 seconds ), then release the
button and set the new handset into the base phone
cradle. After ~ 30 seconds it will beep and display
its "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset
in turn: press "Handset Locator" ~ 4sec
( in-use light on ), set handset into the base
cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Apr 21, 2016 | Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
and it will soon beep and display "Not registered"
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
Can't seem to deregister the used HS I bought on Ebay since I don't have it's base.
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Nov 27, 2015 | AT&T DECT 6.0 Expansion Accessory Handset...
Deregister procedure for at&t el52400 handsets
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
User guide for eurotel e1100
try http://www.binatonetelecom.com the manual for the Activity 2610 looks similar to the e1110 manual.
link
http://www.binatonetelecom.com/resources/0000/0271/Activity_2600__2610_.pdf
Aug 16, 2010 | Cell Phones
Eurotel 1110 cordless phone, manual required unable to clear the messages, mail box full can you help
link
or press menu/ok press down arrow on the big button at the top of phone until ans machine press menu/ok then down button
Aug 12, 2010 | Uniden Cordless Phone
I have a Eurotel E1110 device but it is asking me to register the third phone again. I do not know the pin-number so what can I do?
7.5 Registration
with in this time.
Hope this helps you
Jun 11, 2010 | Lands Phones
I need user manual eurotel e 1100 cordless phone
A scan of the Eurotel e1110 e1100 e1115 phone manual is available from:
http://computernetworkingsolutions.co.uk/user-guides-ezp-7.html
Feb 21, 2010 | Lands Phones
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
587 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
