Question about NetGear WGR614 Wireless Router
Netgear wgr61 Wireless Router
My Router keeps dropping out or experiencing very low reception and I have to continually return to my network settings and connect the router. I'm also not confident that my network is secure and I keep accidentally piggybacking off other wireless signals when my signal gets low. I'm frustrated with this router - and I'm about to start a business from home and rely heavily on my broadband connection. Can someone help me? Marco
  • Anonymous Mar 30, 2014
    wifi reception weak on my ZTE valet would like to increase power setting on my router. Is it possible?
  • 854 Answers
You can also check the settings of your wifi security. I would suggest you use WEP or WPA-TKIP (personal). You can also try considering this options below;
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference
b. Wireless settings of your router
c. Location of the devices
d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB
Metal frame, glass wall into building 6dB
Office wall 6dB
Metal door in office wall 6dB
Cinder wall 4dB
Metal door in brick wall 12.4dB
Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens.
b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab.
e. Change the Network name or SSID to your preference.
f. Change the Mode to g and b only.
g. Change the Channel to 11, 1, 6 or 9.
h. Click on the Apply button.
i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://www.routerlogin.com/basicsetting.htm
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
Posted on Apr 11, 2009
    President:
  • 2,961 Answers
You need a good clear view between your pc and the router to get the best signal, if you have walls and doors and windows, try putting your router higher up to get the best possible coverage, as if the signal does get low your router will drop the signal then automatically look for another connection within it's range. The security of your router should be set at atleast WEP or better WPA allthough this is to stop people connecting to your router it wont stop your pc connecting to other conections unless you set it to only connect to yours and not look for others.
Posted on Sep 09, 2007
Samsung tab keeps dropping wgt624
You are losing the signal? If you move about the area reception will differ. I'm not sure what your question is? May things will cause a signal loss. The device location, device antenna, interference, Wireless Channel, etc. Is the wireless secured? Change NetGear Channels.
Jan 18, 2013 | NetGear : WGT624 108 Mbps Wireless...
Wifi works and all but keeps having my two phones put the password in every half and hour. I don't have the disc for it so can't really set it up just connected it to my charter modem.
Try this please:
  1. eHow
  2. Internet
  3. Wireless Internet & Network Hardware
  4. Netgear Wireless Routers
  5. How to Access Netgear Wireless Router Settings
X Must See: Slide Shows
How to Access Netgear Wireless Router Settings Xno-user-image.gif Ryan Bauer
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
72955587_xs.jpg Wireless routers connect computers to a network without the need for network cables.
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryptionicon1.png," "Network setup details" and "Passwords" can be customized.
Other People Are Reading
Instructions
    • 1
      On a computer that is connected to the routericon1.png with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    • 2
      Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
    • 3
      Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
Read more: How to Access Netgear Wireless Router Settings ' eHow.com http://www.ehow.com/how_4913660_access-netgear-wireless-router-settings.html#ixzz2H3QQJGxn
Jan 04, 2013 | Computers & Internet
When first installed all worked fine but now some 4 weeks later I see the wireless connection keeps dropping and then reconnecting. Also it is incredibly slow. Ran adsl speed test with the modem hardwired...
reset the router and then make sure you have it private. The main issue may be people sponging your network. Also check the stream activity on the network. If you have a main computer make sure it is not downloading large amounts when you are having issues. If none of these are the cause return the router you have a hardware defect.
Jun 28, 2010 | NetGear DGN2000 Wireless Router
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours...
yes set the speedstream modem to log in. it is uner advanced, usually 192.168.0.1 address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
Oct 31, 2009 | NetGear WGT624 Wireless Router
Extremely inconsistent connection to router (Net Gear) & Internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Netgear router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Netgear router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:Netgear suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router:
Having default wireless settings on the Netgear router may cause conflict with other Netgear routers within your network range.Netgear suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Computers & Internet
The Wireless Signal keeps dropping out.
make sure that there are no cordless or wireless devices near the router such as a cordless phone since that will interfere with the wireless signal and a cause for frequent disconnection.
otherwise, the device should be replaced already.
Aug 22, 2008 | NetGear DG834G Router
Signal dropping out when useing netgear adapter
You may find that either the signal strenf=ght is not there or there are other devices near by on the same channel as the router.
Use THIS app to test the signal strength and check the channels is use also
You may want to either move the router to a higher postion (on a shelf) or get an external antenna for it to boost range. Be aware that cordless phones are a source of interferance so thias may affect signal strength, reception etc. Put some distance between such devices and the router/widfi card etc.
Jul 06, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless Network Dropping Out- NetGear WPN824 V.2 & Atheros AR5006EXS Wireless Network Adapter
Fergus,
Steps to troubleshoot are as follows.
1. check the physical connections. Go to a broadband testing site to see if you are connecting correctly b/c i am assuming you are wanting to connect to the internet. if not see next step. A common problem with internet connections is the timeout setttings on netgear you should set it to 0 for indefinite.
2. if your problem is related to just the connection between your pc and your router then you should just plug a lan cable in first to see if you can connect to the router without dropouts. This will help you to determine if the problem is with the router.
3. If it is the router then you need to double check your router configurations. Common problems are firewall rules, port forwarding settings etc etc.
4. if it is not the router then double check that the pc and the network card is working properly. If it is then make sure the the wireless adapter support the protocl eg. wep, wpa, wpatsk etc..make sure they are the same and that you should be setting the network key.
5. one final check is you need to turn off some of the rangemax functionality on the router b/c your wireless adaptor probably doesnt support it. try unsecure connections for a while to see if it works then start adding functionality to determine which one is the culprit.
I hope this help.
smeags.
Dec 31, 2007 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
927 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
