Main unit will not stay on
I have a panasonic sc-ht540 surround system.this has just started to as soon as i power on it will all start coming through the speakers then the machine will turn off..error code f61 comes on which says check speaker cables connections..have done all this but still no joy..i have had this system for only 8 months and never had a problem...many thanks
  • 6 more comments
  • darny Sep 14, 2007
    thanks for replying simplemitch...have checked all speakers cable but looks like it is the amp.rang currys where we got this from and as it still is in warranty they are having a look at it...
  • gurtrex Dec 11, 2007
    I am having the same problem with the code F61. I kinda moved wires around last night and turned the whole unit off, thinking that would clear the code. I will check wires though that sounds like a weird solution.
  • Anonymous Dec 29, 2007
    when power turned on reads"f61" then turn self off??????
  • Anonymous May 24, 2008
    speakers crackled initially and now cannot sustain power.
    tried cheking power cable and speaker connections but all looks ok
  • Anonymous Jul 09, 2008
    i'm getting the same F61 code.  how hard is it to find an amp and replace it?
  • Nova Karen Aug 05, 2008
    as soon as i switch it on it immediately switch off and bring me the F61 error message. tried to unplug all cables but still the main unit can't stay on power
  • marigo Apr 02, 2009
    the same problem....
  • tiagobarbosa Apr 19, 2009
    i had the same problem a year ago, but sudenly it stars to work again.
    It was in warranty whe the problem appeared for the first time, and disapeared alone.
    i thought i would never have the same problem again, but now, it happenend. I´ve tried to switch of all the audio cables, but the problem still happening...
  • 752 Answers
Check to make sure none of the speaker wires are touching the case. If not, unhook them all and see if problem persists. If it does then the amp is damaged. If not then plug one spkr in at a time and check to see which one is causing the problem.
Posted on Sep 13, 2007
    New Friend:
  • 14 Answers
The promblem could be that one of the two fans stops running. This causes a feedback response to the circuit system and shuts down with F61 error. Replacing the fan is easy and should not cost any more than £5
Posted on Mar 01, 2010
Cehcked all speakers...all are fine.  what is the difficulty in replacing the amp???
Posted on Jul 09, 2008
SOURCE:
Panasonic SA-PT467 I am trying to find the original description of my DVD home theatre system. I cannot find anything about it!!
Manual and Review
Panasonic SC-PT467 Manuals
https://www.manualslib.com > Brands > PANASONIC Manuals > Home Theater System
  1. Cached
Manuals and User Guides for PANASONIC SC-PT467. We have 1 PANASONIC SC-PT467 manual available for free PDF download: Operating Instructions ...
Panasonic SC-PT467 Home Theater System ' Product overview ' What ...
www.whathifi.com > Products > All-in-one-systems > Surround systems
  1. Cached
  2. Similar
Panasonic SC-PT467 Home Theater System overview from the experts at What Hi-Fi? - compare latest prices, see user reviews, and see specs and features.
Panasonic SC-PT467 5.1 Surround Sound reviews, prices and deals ...
https://www.reevoo.com > ... > Sound channels : 5.1 surround sound > Panasonic
  1. Cached
  2. Similar
Rating: 8.4/10 - ‎33 votes - ‎Price range: Compare prices Latest Panasonic SC-PT467 reviews, ratings from genuine shoppers. Find best deals and buying advice from consumers on Panasonic SC-PT467 from Reevoo. Surround sound effect‎: ‎8.8 Clarity of instruction manual‎: ‎6.9 Sound quality‎: ‎8.4 Panasonic SA PT467 Google Search
Dec 05, 2016 | Panasonic Audio Players & Recorders
Panasonic SC-AK78 The stereo lights dont come on , no sound . I i I have to turn the power on & off numerous times for it to work , the lights sometimes stay frozen ,meening if i change from stereo...
This is a sign of a power supply problem. These units use what is called a "switch mode" power supply. These use a capacitor to kick-start the power supply. While I can't say for sure, this is the most likely cause. There are other components that can be close to failure later in the circuit that can cause this as well. Without seeing the actual unit and testing the circuits, there is really no way for me to know. You should expect to pay in the $20 range for parts for this repair.
Dan
Aug 18, 2011 | Panasonic SC-AK78 CD Shelf System
I can't get surround sound when I want to watch a dvd. I need to know how to set it up properly. This is for a Panasonic Home Theater Audio System MODEL NO. SC-HT65
the wires are color coded, follow the color coding on the wires, and connect the wires to the proper color coded connectors on the back of the main unit or go to panasonic.com to get the manual online for that model
Jan 21, 2011 | Panasonic SC-HT65 System
Panasonic SC-HT995W Home theatrer System
It's probably a ventilation fan that's making the noise. Locate it and see if you can clean out any dust or dirt in it.
Apr 30, 2017 | Panasonic SC-HT995W System
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
No power!
every thing is working the system and the subwoofer my problem is the center and surround speakers are not working
Nov 20, 2007 | Panasonic SC-HT720 System
No surround sound in tv or vcr mode
For some reason this Panasonic unit does not offer surround sound in TV or VCR mode.  I guess their engineers decided it wasnt an important feature!!
Oct 21, 2007 | Panasonic SC-HT730 System
MAIN UNIT PROBLEMS
the sound is coming out of the front speakers good but not the center and surround
Aug 11, 2007 | Panasonic SC-HT720 System
Panasonic SC-HT900-problems with surround sound mode and digital input
i have the same probelm when playing a dvd does it work then when u press the surround sound button it goes slient ???
Oct 16, 2006 | Panasonic SC-HT900 System
943 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
