Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Polaroid HD flat screen TV with DirecTV
By criter on Sep 09, 2007
I pressed some wrong button on control trying to use DVD. Now nothing works except the power. I have pressed reset
button and unplugged TV for 15 minutes.
I am trying to get it to go on vidio 6 to watch TV,
Instructions say TV must be on "setup" channel to work., and to use Mode button to go to "setup"
I find a setup button at top of the polaroid remote. Is that the one to use? On the Direct TV remote is a button that moves right or left. On the left is a directv logo. I leave it set on that. Is that the "mode" button?
Same Problem
Apr 09, 2009
-   There is a infrared Red light that is on when the TV is in OFF mode. Very annoying when you are trying to sleep.
If there a way to turn it off?-   ester822
Feb 25, 2009
-   i have never used DVD til today .having same problem as everybody else on model :TDA-03211C-   ITOPAZ19
Jan 16, 2009
-   I have a polariod flate set, when turn-on I get a white screen and some time sound. what may be the problem? Sometime I get vertical colored lines that fad out when set is truned on.-   Guest
Sep 16, 2008
-   I have the same problem , i was using the directv remote to control my dvd player and must have pressed a wrong button now the only button that works on the remote for the tv is the power button. And the only button that works on the actual tv is the power button as well. The volume,channel,menu and input buttons on the tv are not working. The sound and picture are fine because i switched the inputs from the dvd to directv and no problems.I called Polaroid and they said i could send them my tv and they would send me a refurbished one for $300 but i feel there is a easy fix but they just wont tell me how to do it. Any help would be appreciated , i lost the actual remote a few months ago not sure if buying another one would solve the problem. -   dpasternak15
Aug 15, 2008
-   I AM HAVING THE SAME PROBLEM WITH THE DVD PLAYER, MY SON PUT THE DVD IN AND NOW WE CANT GET IT OUT,,, DOES ANYONE KNOW WHAT TO DO?-   Guest
Best Solution
posted on Apr 18, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Press input and then select dvd. After a few moments the dvd will start up if one is inserted.
Solution #2
posted on Mar 24, 2008
Helpful)
pcland_com
Rank: Apprentice
Rating: 92%, 9 votes
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Was this helpful?
Yes
No
Solution #3
posted on Mar 09, 2008
Helpful)
leegf
Rank: Apprentice
Rating: 91%, 5 votes
Our new Polaroid flat sceen has the built-in DVD player, for some reason the DVD will not play. All it shows is "No SIgnal".
Please Help!!!
Was this helpful?
Yes
No
Solution #4
posted on Sep 09, 2007
Somewhat Helpful)
Leadtech
Rank: Guru
Rating: 88%, 427 votes
If your television is programmed to that remote, then, at the top of the remote, change the switch that moves right to left to TV. Find the button that says Input and press it until it goes to video 6 on the Television.
Then turn the switch that moves from right to left to cable to operate the cable box.
Normally, on most televisions there is an input button on the set that can be pushed to get to the input you want.
If this doesn't help respond to this post and I will reply.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how to unlock sansui channels
Answer
how to unlock channels
Answer
There are no closed caption options in setup menu and I do not have a remote
Answer
I switch on my logik log37lw782 and the blue standby led light come on but when i press a button on... (More)
Answer
sound no picture This Tv has been in a model home for 3 years unused. Home was sold 3 weeks ago and... (More)
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 03, 2008
dido
Comment by jackj, posted on Nov 06, 2007
Bought a new POLAROID mod FLM 3238 hd tv. Have direct tv with a D11-300 receiver and an RC23 remote. I can not control the power, sound or mute with the RC23 remote. I have to use the Polaroid remote to control these. This means that I have to use two remotes to control one device. I've called direct tv and POLAROID techs. many times and they can not figure out the problem. The guy that installed the direct tv said that if I would have bought any other brand other than POLAROID, the RC23 would work. I have a feeling that I need the right setup code(which no one seems to know). Could anyone help me with this problem?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
