MSI K8N NEO2-Platinum  Motherboard
Problem for MSI K8N NEO2-Platinum (MS7025) Motherboard
Does not go to first post on boot up & no graphics, all fans work
By kyles_grampy on Apr 10, 2009
installed second hand mobo into new case, this board was removed from a working pc, after being wired up & switched on the heat sink & case fans kick into life also cd rom lights light up, hard drive motors also work, replaced bios battery, power pack & flashed bios, did notice when flashing bios there was no fan rotation when powering up the mobo when removing bios memory, this mobo was stored in an anti static bag & boxed for six months prior to re use, tried powering mobo with every think disconected from board, still wont post & no graphics
Comments:
Apr 11, 2009
- I am using three 512mb sticks of ram, each ram is from a different manufacturer, Kingston, Crutial & Twinmos, the processor is an AMD athlon 3700 to suit a 939 socket.
Clarification Request
Posted by DickCanFixIt on Apr 11, 2009
One or more of the memory modules is incompatible. Install only one and attempt to boot, swap with another until it will boot, then add memory until it will no longer boot.
Posted by DickCanFixIt on Apr 10, 2009
What processor and RAM are installed on the motherboard?
Solution #1
posted on Sep 12, 2009
Not Rated)
dncholas
Rank: Master
Rating: 78%, 6 votes
Sounds like an experiment I did on a mobo seeing how quickly a cpu shuts off without proper cooling. You don't mention which fan, but if the cpu fan is not working then your cpu is going into shutdown. Same would happen if cpu fan worked but not installed properly. But would show bios startup. Also flashing the bios is risky and can ruin a mobo. Possibly the mobo already had a problem before you got it. Check all wires and connections and especially the cpu fan
Was this helpful?
Yes
No
Solution #2
posted on Apr 16, 2009
Not Rated)
exil0r
Rank: Guru
Rating: 85%, 79 votes
Check the memory and/or vga card
Was this helpful?
Yes
No
Popular Solutions for MSI K8N NEO2-Platinum
Questions and Unsolved Problems for MSI K8N NEO2-Platinum
Do you recommend MSI K8N NEO2-Platinum (MS7025) Motherboard?
Answer
Answer
what motherboard is fitted to an Asus a6000km laptop and where can I get a replacement
Answer
open medion akoya E7330 pc case
Answer
dont know the correct jumper settings for my e machin.es t6534 monitor doesnt read as on. please... (More)
Answer
gateway laptop powers up but screen doesn't come on
Answer
jumper was blown off during maintence,i put it back to where i thought it was only to discover i... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , IL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
