Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My sound drives get uninstalled
Sir, i have a computer with configeration pentium-3 processor chip set, 40 g.b memory, 256+128 m.b ram, c-media drivers are needed for my operating system windows-xp. they get uninstalled soon after installing them. it says in disk manager that the drives are incorrect. please suggest me the solution or tell me which drives suit the best. my driver code is cmi-8738.
Delete whaterver sound driver is installed and then try to find a driver of c-media on driverskit.com
Posted on Sep 10, 2007
  • 57 Answers
First delete whatever is causing the problem from device manager. When the computer restarts you may find that the correct driver is installed. If not then you could try this driver http://www.download.com/C-Media-CMI8738-WDM-Driver-Windows-XP-/3000-2120_4-10495783.html
Posted on Sep 09, 2007
SOURCE:
What equipment goes to intel Pentium processor I i have a monitor mouse and keyboard
You only have a small part
You need;
a case
a power supply unit
a motherboard for the Pentium processor chip to fit into.
RAM memory modules
a Hard Drive
I am wondering if you are just reading a sticker on a computer case?
Click COMMENT under my post to answer.
Jun 25, 2018 | Intel Computers & Internet
Dc5100 processor upgrade
NO!
Two Netburst based Processor cores on the SAME chipset?
Get outta' here!
When did they come up with that?
OH, I'M JUS KIDDIN'!
http://h18000.www1.hp.com/products/quickspecs/12145_na/12145_na.HTML
The HP Compaq dc5100 Desktop PC uses an Intel 915GV motherboard chipset.
Since we know that the Northbridge chip, of the motherboard chipset; handles the Faster capabilities of a computer;
i.e., Processor, Ram Memory, and HIGH-speed graphics; let's look at the Intel 915GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
No sir/ma'am.
The Intel 915GV motherboard chipset only handles Single Core processors;
Intel Pentium 4,
and,
Intel Celeron,
and,
Intel Celeron D.
(With a 533MegaHertz Front Side Bus, or an 800MHz FSB)
The Celeron D is NOT a dual core processor,
http://en.wikipedia.org/wiki/Celeron#Prescott-256
"The D suffix actually has no official designation, and does not indicate that these models are dual-core. It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers) Unlike the Pentium D, the Celeron D is Not a dual core processor."
Yeah, I know. I'm just a 'Ray of Sunshine'.
You know you can pick up a motherboard pretty cheap nowadays, that WILL support the lowly Pentium D, for not much money.
Problem is you will need to replace Ram Memory also.
By the time you get a motherboard chipset that supports dual core Processors (CPU), you are going to be using DDR2 Sdram ram memory, instead of the DDR Sdram ram memory you are using now.
OK, Motherboard, CPU, and Ram Memory.
Oh, the Power Supply. Won't do either.
240 Watt unit, or 300 Watt unit?
Sure.............OK.
Back in the day those Power Supply's were made, Power Supply manufacturer's were 'fudging' the actual maximum rated Wattage.
True Wattage was more like 60 to 70 percent of what was stated.
Why?
SOLD more Power Supply's.
240 Watts?
Simply divide by 10. = 24.
For 60 percent, take 60 times 24. = 144 Watts
70 percent? 168 Watts.
300 Watts?
60 percent is 180 Watts.
70 percent is 210 Watts.
I wouldn't try to run a Barbie doll with that low a Wattage, of Power Supply. (Barbie doll? What?)
Need at least a decent 350 Watt power supply, from today's manufacturers.
80 percent constant duty cycle, for most good units; or higher.
So...............
Max out the Intel Pentium 4 CPU.
4GB's of 533MHz DDR Sdram ram memory.
(PC4200, or PC4300. Depends on the manufacturer as to how they name it)
By the time you spend that much money, you may as well buy another Motherboard, Processor, Ram Memory, and Power Supply.
Yes, may as well buy a better computer.
I know. Quit trying to cheer you up.
Around here we have Craigslist, and Ebay, for two places.
Could pick up a better computer, for around the same money, as you would pay for all the upgrade parts above.
Which is better? Upgrade the Processor, or upgrade the Ram Memory/
For the better 'Bang for the Buck', upgrade the Ram Memory.
The CPU (Processor) has a built-in cache.
L1 cache, and L2 cache. (Newer CPU's have an L3 cache)
The Cache is a small memory area for the CPU.
It is the FIRST memory area the Processor (CPU) reads.
This is because it operates at the same frequency rate, as the CPU does.
(Frequency rate = 'Speed'. Operates at the same 'Speed')
Next inline is the Ram Memory.
Ram Memory -> typically, operates at half of the Processor's Front Side Bus. (FSB)
This is why upgrading Ram Memory is a good idea.
It isn't so much of getting Ram Memory, that operates at a higher frequency rate ('Speed'), as it is to have MORE ram memory.
Example;
PC3200 compared to PC4200.
4GB's of PC3200 is better than 2GB's of PC4200.
(DDR Sdram at 400MHz = PC3200)
Moving on............
Motherboard chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset for your computer, consists of a Northbridge chip, and a Southbridge chip.
{Motherboards that support the Intel Core i technology, (Core i3, Core i5, Core i7, etc), do NOT use this motherboard chipset technology. Neither do some of the AMD CPU's }
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
As stated previously, the Northbridge chip handles the Faster capabilities of a computer;
Processor (CPU), Ram Memory, and HIGH-speed graphics.
The AGP technology, and the PCI Express technology; ARE high-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics; is NOT high-speed graphics.
The slower capabilities of a computer are handled by the Southbridge chip.
1) PCI Bus / Integrated Graphics.
(Another term for Integrated Graphics, is OnBoard Graphics. A term that seems to have gotten lost.
It explains better; ON the motherBOARD )
2) IDE Bus
3) SATA Bus
4) USB Bus
5) Ethernet
6) Audio (Sound)
Point?
Look to see what the Northbridge chip is, as I have shown you; and you'll get a good idea of what Processor (CPU) support is.
For additional questions please post in a Comment.
Regards,
joecoolvette
(I get tired of looking on websites, that just say NO, and do not explain why )
Mar 06, 2013 | HP Compaq dc5100 PC Desktop
What is the uses of the memory
Depends on what Memory you are referring to, yampratwum
1) Cache for a Processor;
A small memory area on the Processor.
(L1 and L2. Some Processors also went to L3 cache)
Cache operates at the same frequency rate ('Speed') as the Processor.
It is the First memory area the Processor accesses.
http://en.wikipedia.org/wiki/CPU_cache
http://computer.howstuffworks.com/cache.htm
http://www.hardwaresecrets.com/article/How-The-Memory-Cache-Works/481
2) Ram Memory;
Volatile memory.
Once the computer is turned off, all memory stored in Ram Memory is GONE.
Ram Memory typically operates at half, of the frequency rate of the Processor's Front Side Bus. (FSB)
It is the Second memory area that the Processor accesses.
http://computer.howstuffworks.com/ram.htm
3) Harddrive; (Hard Drive. Hard Disk Drive)
This is the Third memory area the Processor accesses.
There is also a small memory area on the harddrive.
This is it's Cache. It is called the Buffer.
http://computer.howstuffworks.com/hard-disk.htm
http://en.wikipedia.org/wiki/Disk_buffer
http://www.hardwaresecrets.com/printpage/177
4) Virtual Memory;
An area on the harddrive that Windows has allotted.
Rule of thumb is Virtual Memory is one and one-half, (1-1/2) the amount of Ram Memory.
Example;
2GigaByte (2GB) of Ram Memory?
Typically Virtual Memory will be 3GB.
http://en.wikipedia.org/wiki/Virtual_memory
5) BIOS;
Basic Input/Output System
A program that is flashed to an EEPROM chip. The BIOS chipset.
Another small memory area.
http://computer.howstuffworks.com/bios.htm
http://computer.howstuffworks.com/computer-memory.htm
Regards,
joecoolvette
Nov 05, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
3 SHORTBEEP CODES ON STARTUP BOARD - G41-M7 PROCESSOR - INTEL CORE 2 DUO RAM - 4GB HARD DRIVE - 320 GB SATA
usually that signals a memory failure of some kind, try pulling some of your ram chips and trying different configurations.
Sep 06, 2011 | Biostar G41M7 Motherboard Intel Pentium...
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
Sep 20, 2010 | Gateway Essential 400 PC Desktop
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
