Canon MX 310 - printer not detected message
I am running the disk to install this printer and once I get to the printer connection page I plug the printer in and the computer does not detect it
  • Anonymous Feb 16, 2008
    uninstalled reinstalled
  • Anonymous Aug 26, 2008
    Using Mac Book Pro with OS X 10.4.11
    and an Airport-
    The printer only shows up when plugged in via USB or as a shared printer
    but it is not detected when used as a network printer
I have mx 310 printer but the disk is missing. I cannot install request help in this matter thank you
my e mail is [email protected]
Posted on Feb 18, 2008
I had same problem all i had to do was re install upgrade ver of vista over existing one must have been a file missing works great now
Posted on Oct 11, 2007
    Brigadier General:
  • 6,966 Answers
Hi, I will assume that you are installing the Canon MX 310 to a Windows machine. Before going thru the install procedure, please check that you have USB enabled by right click on My Computer, Properties, Hardware, Device Manager, and at the very bottom USB Controllers should be there with no red or yellow markings. If they are not there, please restart your machine, press del or whatever it is to enter CMOS/BIOS setup and verify that the USB ports are enabled. In some instances, it may take some time before the PC recognizes the USB device such as your printer. You really have to give it time or one trick is to Cancel the printer port detection and just go ahead with the installation. When all is installed and finished, you can change the properties of the printer to USB port from the Parallel/LPT1 port. Another is to plug the printer straight in to the USB port (or try all the other USB ports) without installing it first. Allow/let Windows to autodetect and auto install. Put in the CD only when Windows does not know where the drivers/installers are located. Hope this be of some idea/help. Post back should you need further information. Good luck and kind regards.
Posted on Sep 09, 2007
SOURCE:
Can't seem to find how to put ink into my canon mx 310 printer
I'm assuming when you said "fine catridge" you meant FINE cartridge. FINE is an acronym for the Canon Ink Cartridges. Anyhow, plug your printer into the electrical outlet and turn the power on. Wait about 1-3 minutes and open it up and the Ink Cartridge holders should move to the left for you to properly insert your Ink Cartridges.
Jan 31, 2013 | Office Equipment & Supplies
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
Installing canon pixma 310 printer to windows 98 os
  • Connect the printer to the computer.
  • Insert installation disk into CD/DVD ROM.
  • Go to my computer and double click on the printers icon to run setup,
  • Follow instructions till setup finishes installations.
If you don't have windows98 drivers for the printer download from here.
Hope this helps.Thanks!
Oct 15, 2011 | Canon PIXMA MX310 All-In-One Printer
I am trying to hook up a Canon MX 310 to my MAC and tried to download the driver and end up with an error message. Failed many times and just can't figure it out...can you help?
Depending on which Mac OS you are running you shouldn't need to download a driver - most Canon printers are included in the Apple software from X10.5
Jun 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Can i add my Canon MX 310 to my Macbook Pro - OSX 10.6.6 ? Do I need to download a new driver?
Sure you can. Canon MX 310 supports Mac OS X. Just click on the link below to go to canon's download page.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310
Just click Drivers and Software link and choose for your OS from the dropdown link.
Hope this helps. Thank you for using FixYa.
Jan 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 scanner driver not found
Hi there
You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the MX310 it for XP and Vista.
Click Link = http://www.4all2sell.com/driver/Canon-PIXMA-MX310-All-in-One-XP-Vista.exe
Ones you have downloaded just double click on it to run it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks All files on my website are only there for a limited time.
Mar 23, 2010 | Canon MX310 Office All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
Mar 30, 2009 | Canon PIXMA MX310 All-In-One Printer
MX 310 Not seen in Mac printer list, so cannot install
Had a new hard drive installed and need to re-install Canon Pixma Mx 310 all in one back in my Mac
Dec 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Jul 03, 2008 | Canon PIXMA MX310 All-In-One Printer
Open Questions:
1,784 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
