Question about E-Machines C1641 PC Desktop
Dead PC My mums pc had a few viruses on it and was running like a slug so i cleared the cmos ready to do a clean install i tried to flash the bios which ive done before on my own computers but i just cannot get the jumper switches right.been up 2 nites now so am ready to jump off the nearest building any help would be fab thanks. juicyone
  • 520 Answers
Smart looking pc's work well .;but run like slug even with a fresh install.(vista)
install xp and notice the difference.
if you remove the rtc battery for a few minutes then replace your bios will be reset to factory default.
Posted on Apr 01, 2008
    Brigadier General:
  • 6,966 Answers
Hi, When flashing a BIOS, you would need a bootable diskette (or CD) with basic DOS and the ROM .bin or BIOS update files plus the flashing software. In the CMOS/BIOS setup, you have to instruct the computer to boot first from the floppy diskdrive (or the CD as the case may be). Then run the flashing software/application and type in the filename of the new BIOS. Most modern motherboards no longer uses jumper switches to allow/disallow BIOS writing/update. If for some reason there are jumper switches, perhaps we can confirm if you would post the brand/model/version of the motherboard/computer. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Posted on Sep 09, 2007
  • Louie  Role
    Louie Role Sep 09, 2007
    Hi again,
    It may be that you just relocated the jumper pins of the CMOS reset which as you posted should clear the CMOS/BIOS setup and set it to default.
System options not set hp compaq dc 7600
Make sure your clear cmos jumper is not in the clear position! It is usually close to the battery and there is labelling on the mboard near it. If you're sure you didn't move it, then don't worry about that.Did you try setting the bios to defaults?
One possibility - it could be it does this if you don't re-set at least the date (and possibly the time) in the bios from the default it sets itself to when you remove the battery or use clear cmos - set it to today's date and time, or to anything other than the default, save settings.
If after you save the above settings, turn off the computer for a few minutes, and check the bios again, the date and time re-sets to defaults, then the cmos doesn't see the battery. If the date and time are consistant with what you set them to, it is seeing the battery.
By the way, I don't think this is the problem because you have the 162 error code, but make sure the battery polarity is right - is in the holder the right way - and the contacts for it are making good contact - if it is the wrong way or the contacts are poor, the cmos will think there is no battery. Usually you can tell by the way the contacts are arranged which way it goes - if it is the wrong way both contacts touch the same part of the coin cell (if that is what you have) - usually + is upwards.
If setting the bios to defaults, setting the date (to anything other than the default) does not get rid of the error message, try making sure everything on the board is properly seated. Unplug the computer when you do that!
..... says memory error, below that it says 162 System Options not set, then it says 164 error.
I just took everything that would unplug and reset them in and it corrected the problem. Thanks
That error code is common on many computers, and in many bioses.
161 POST Error - System options not set - (Run SETUP) - battery
162 POST Error - System options not set - (Run SETUP)
161 System options not set; dead battery
162 System options not set; CMOS checksum/configuration error
If it is 161 the battery is dead, it is installed with the polarity backwards, or the battery contacts are not making good contact.
If it is 162, there is nothing wrong with the battery - you need to go into the bios Setup.
I have found nothing other than the above post about what to do about that.
If you still have issues, go to and talk to one of our techs
Clean Optimize Speed Up and Secure PC Freeware Download EZ System Repairs
Oct 15, 2015 | HP Compaq dc7600 Small Form Factor PC...
Laptop does not turn on after bios update
Try setting the BIOS to default, then rest the settings.
You can try to re-flash the BIOS version just before the latest version.
The Wz number you posted does not match a 655.
Read the manual carefully about how to flash the BIOS.
Look in manual for clearing CMOS, if you have it, clear CMOS, set BIOS to default, and reset, if this does not work, re-flash the next to oldest BIOS version, if you have (example) F23, then flash to F22.
Dec 06, 2012 | HEWLETT-PACKARD HP ProBook 6550b Notebook
I replaced the cmos battery and cleared it
You cleared your cmos while windows was installed. NEVER reset, clear or load default w/o backing up your system before. You changed something in the bios that is no more according with the windows configuration. Good to find what. Try to reconfigure your bios maybe it will solve your problem. But if not you've to reinstall windows.
Aug 05, 2012 | Dell Dimension 8400 PC Desktop
I have a challenge for you experts.A friend ask me to see if I could repair his computer he was given by his mum that was in the atic for at least 6 month (Packard bell i design 190) I put all the cables...
WOW, this sounds so familiar, try changing the CMOS battery, I got the same exact error mess in a old packard bell i refurbished for a friend and a simple change of the cmos batter solved the issue, it even let me install xp with not problem,, its worth a try.... :)
Sep 04, 2011 | Computers & Internet
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
How can i remove bios password
disconnect your laptop battery and, bios battery on the mother board wait 10 minutes plug the bios battery back in then; reboot without installing the laptop battery: your passwords will be removed
May 20, 2009 | Computers & Internet
I need to know where the cmos or bios reset jumper are on a Toshiba Satellite A210. Maybe a picture of the board would be great. I'm trying to reset the bios password.
Try removing the battery inside for the bios, and the jumper for clearing the CMOS. or try flashing the bios. I am sorry, because its very dificult to get the inside pictures of the laptop. Otherwise Download the latest bios and install it in your laptop. Hopefully it should work. Thank you
Sep 10, 2008 | Computers & Internet
Will not power-up after a shut down unless the CMOS is cleared.
try swapping the Ram Chips "Memory" try running it with less memory or if you have multi chips take a few out and run it
Good luck
Please rate US! thanks
Jul 14, 2008 | ASUS P4P800-MX Motherboard
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
E-Machines C1641 PC Desktop Logo
66 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
