Question about Samsung LN-S2651D 26 in. LCD Television
Same thing It says the same thing, mode not supported, when I try to plug in my laptop.
  • 1 more comment
  • gsmith3805 Feb 11, 2008
    My S2651D problems started with the rapid horizontasl lines. My laptop is hooked up and I use the lcd primarily for my latop. The laptop's screen is fine when the lcd startes with the horizontal lines rapidly going up. Then this past week it sarted going into the "not supported mode" I thought I had it fixed once (although I don't know what I did either then go into Display settings and messed with the max resolution on my Toshiba laptop). Prior to this everything was fine. After that first fix, Netflix movies were coming in with no problem, then it slipped back into the "not supported mode" again. Tried changing to the higher resolution. Negative results. Thanks for any response that can help.
  • Anonymous Feb 21, 2008
    i was playing games on my xbox360 when the lines started to cover the screen and now it says "mode not supported"
  • gsmith3805 May 11, 2010
    TRIED THE TWO SUGGESTIONS AND CHANGED THE SETTING. COMPUTER SCREEN RETURNED TO THE TV. LEFT IT FOR A FEW MINUTES TO MONITOR THE IMAGE AND IT WENT BACK TO THE HORIZONTAL LINES/FLUTTERING VERTICALLY ACTION. THE COMPUTER SCREEN WAS VISIBLE. FLUTTERING STOPPED FOR A COUPLE OF MINUTES AND THEN RETURNED. THAT OCCURRED FOR A COUPLE OF MORE TIMES AND THEN IT WENT INTO NOT SUPPORTED MODE AGAIN. WENT BACK IN TO CONTROL PANEL AND THE ORIGINAL SETING I HAD MOVED IT TO DID NOT APPEAR ON THE SCALE. THE SCALE WOULD JUMP FROM MAX TO MIN FOR THE RESOLUTION. I'M THINKING MY TOSHIBA SATELLITE OR SOFTWARE IS THE PROBLEM. DON'T KNOW WHY THE SETTING AUTOMATICALLY CHANGES ITSELF OR DOES NOT APPEAR ON THE RESOLUTION SCALE IN SETTINGS. MAHALO (THANK YOU) FOR THE KOKUA (HELP) gsmith3805
It's fine, i figured it ou. My laptop's a widescreen and the TV didn't support 1280x800, which the laptop was set to. once i changed it to 1024, it worked like a charm
Posted on Sep 09, 2007
    Novelist:
  • 192 Answers
Normally, you will need to change a setting in your control panel of your laptop to a monitor output. You can change it from your LCD on your laptop to Monitor only or change it so both will operate at the same time. I use my laptops to play DVDs on my customer's televisions to check for some video issues. I'm not in my shop today, but, if you still have problems, respond to this post and I can get back to you later on in the week.
SOURCE:
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
May 28, 2018 | Toshiba Computers & Internet
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
My MacBook has been on this screen for at least 10 minutes. What do I do?
Do you have any devices plugged in, such as an external drive or an iPod? If so, remove them and try again. If this dosnt help then try rebooting in safe mode Try restarting in Safe Mode http://support.apple.com/kb/HT1455
If it still fails to boot up then have a look at this: http://support.apple.com/kb/TS1365
Jan 15, 2013 | Computers & Internet
SAMSUNG TV- model: HLN4365WX/XAA: Component 2 mode not supported
One thing to try is whatever (a box?) connected to that input--remove power from for a short while and then plug back to see if that will reboot the unit connected there.
May 23, 2012 | Televison & Video
When I take my laptop out of hibernation mode, it automatically (almost 95% of the time) goes to a blue screen with very tiny lettering and then re-boots itself. After the re-boot, things seem to be ok.
It's crashing when you take it out of hibernation. Try not to use hibernation mode, in my experience it's more trouble than it's worth , especially with laptops. Also do a search for problems relating to hibernation on your laptop (ie your make and model), there should be a solution out there somewhere, and try the support section of the manufacturers website.
Feb 04, 2011 | Computers & Internet
Can only access laptop in safe mode,when laptop open in full mode the taskbar indcates plugged in but battery not charging, is it battery not charging that is causing this problem or is there something...
Hi. Try to disable all start up items by clicking Start, then Run then type msconfig then Enter.
Go to the start up tab and click disable all button. Leave a checkmark on your antivirus box before closing and restarting the computer. See if it restarts normally. You might be having software conflicts causing the freezing of your screen.
With regards to the battery not charging, try to update your BIOS from this link:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False
Oh, Don't forget to select your type of Operating System and follow the instructions on how to flash your BIOS correctly.. ^_^
Jun 06, 2010 | Dell Inspiron 1525 Notebook
My Vaio will not come out of standby mode without having to be shut all the way down and rebooted, I have adjusted the power setings to ensure that nothing is preventing it from going into standby mode....
If the 10-sec thing doesn't work, then try this:
- unplug the mains power.
- remove the battery.
- leave for a minute.
- fit the battery back.
- plug in the mains lead.
- try switching the laptop on.
If it works, then run Windows Update to download the latest fixes to try & stop this happening again.
If it does happen again, try going to the website of the laptop's manufacturer & check on their Support pages to see if they have a fix for your problem.
Jan 16, 2010 | Sony VAIO VGN-FE550G Notebook
Hp zx7000 laptop hangs on startup hp logo
Try starting it in safe mode. Instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial61.html
If it boots in safe mode, use msconfig to disable all startup items, then selective enable things one at a time until you find the program or driver that might be causing it to hang.
Instructions here: http://support.microsoft.com/kb/310560
If it will not boot into safe mode, you will probably need to try a repair install of Windows. You may want to consult a professional for that, depending on your skill level.
Jan 28, 2009 | IBM ThinkPad T41 Notebook
Samsung LN-S2651D 26 in. LCD Television Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
